Padding on deck under the chain?
mgarr682
City/Region: Asheville
C-Dory Year: 2013
Vessel Name: Glenda Jean
Photos: Glenda Jean
PostPosted: Sat Jan 12, 2013 5:22 pm    Post subject: Padding on deck under the chain? Reply with quote
I installed the anchor rode on my boat today and I'm wondering how badly that ten inches of deck between the anchor stock and the deck pipe is going to get beat up with the chain laying on it. Any thoughts on how to protect that area over the long term?
tomherrick
Guest
PostPosted: Sat Jan 12, 2013 5:50 pm    Post subject: Reply with quote
I've not gotten as far as installing these parts on my boat yet, but am thinking that an anchor chain tensioner should do the trick for you. Rather than padding the deck below the chain, it's pulled tight enough not to bounce off the deck. Below is a pic of the first one I found online. A number of variants are available.
Rob & Karen
City/Region: Franklin
State or Province: TN
Vessel Name: Life of Riley
Photos: Life of Riley
PostPosted: Sat Jan 12, 2013 5:52 pm    Post subject: Reply with quote
I use plastic tubing that I slit length wise on my chain. See pic below.
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Sat Jan 12, 2013 6:01 pm    Post subject: Reply with quote
I use a length of split firehose.
ShellBack
City/Region: Victoria
Vessel Name: Thalassa
Photos: Thalassa
PostPosted: Sat Jan 12, 2013 6:28 pm    Post subject: Reply with quote
Fire hose works great. That is what we use, basic but does the job
PostPosted: Sat Jan 12, 2013 11:26 pm    Post subject: Reply with quote
I have the anchor tensioner mentioned by Tom. I have had windlass in the other boats--never been a real problem. If it is, use tubing to cover it--could even be the foam used for insulation of water ;pipes--cheap and soft. I always carry some 1.5" fire hose to use as chafing gear.
PostPosted: Sat Jan 12, 2013 11:35 pm    Post subject: Reply with quote
<stuff clipped> I always carry some 1.5" fire hose to use as chafing gear.
I just carry a tube of Desitin. Wink
mgarr682
C-Dory Year: 2013
Photos: Glenda Jean
PostPosted: Sun Jan 13, 2013 9:14 am    Post subject: Reply with quote
That's a simple idea and I happen to have a section of that in the basement left over from another project. I'll give it a try, thanks!
bridma
City/Region: Comox
Vessel Name: Nomad
Photos: Nomad
PostPosted: Sun Jan 13, 2013 11:33 am    Post subject: Padding on deck under the chain? Reply with quote
Look in my album under mods. Easy and inexpensive. Held in place by a couple of dollops of Marine Goop (Canadian Tire).
Martin.
PostPosted: Sun Jan 13, 2013 12:19 pm    Post subject: Re: Padding on deck under the chain? Reply with quote
Martin.
Here's the image from Martin's album.
Page generation time: 0.029s (PHP: 67% - SQL: 33%) - SQL queries: 26 - GZIP disabled - Debug on
