Sierra & Racor cartridges interchangeable?
marco422
City/Region: Salt Spring Island
Vessel Name: Gaiasika
Photos: Gaiasika
PostPosted: Sun Jan 09, 2011 10:26 pm    Post subject: Sierra & Racor cartridges interchangeable? Reply with quote
Can anyone tell me if the dimensions, threading and design of Racor & Sierra fuel filter elements allow them to be interchangeable?
Jack in Alaska
C-Dory Model: 26 Pro Angler
Vessel Name: HIGH TIDE II
Photos: HIGH TIDE II
PostPosted: Sun Jan 09, 2011 10:36 pm    Post subject: Reply with quote
Also include the Honda filters in that question.
Desolation Cruiser
City/Region: Powell River
PostPosted: Mon Jan 10, 2011 4:01 pm    Post subject: Reply with quote
We sell both brands here.
If you give me some part numbers I should be able to tell you if they are interchangeable.
mjsiega
City/Region: NYC
State or Province: NY
PostPosted: Mon Jan 10, 2011 7:59 pm    Post subject: Reply with quote
I've used Mallory and Sierra interchangeably.
Desolation Cruiser
PostPosted: Mon Jan 10, 2011 8:31 pm    Post subject: Reply with quote
They both make many different filters and they are definately not all interchangeable.
Matt Gurnsey
Dealer
City/Region: Port Orchard
Photos: Kitsap Marina
PostPosted: Tue Jan 11, 2011 12:22 pm    Post subject: Reply with quote
Racor makes a number of different "heads" for their filter assemblies. Some of them are the same as the Sierra. As well as Mercruiser, BRP and others.
I haven't looked at a Honda filter, so don't know for sure. We usually use the Mercury Filter for installations because it is the same as many others, and is reasonable inexpensive for the whole kit. The exception to that would be Yamaha installations because of Yamaha's System Match warranty.
Matt Gurnsey
Kitsap Marina
www.kitsapmarina.com
360-895-2193
(888) 293-7991
marco422
Photos: Gaiasika
PostPosted: Wed Jan 12, 2011 12:01 am    Post subject: Reply with quote
The reason I am asking is that I installed a Sierra fuel-water separator in the splash well last year and have been thinking I would like to have the Racor type I used to have with the clear bowl where you can drain off the water. So I was wondering if I could just install a Racor filter and clear bowl on the Sierra assembly.
Matt Gurnsey
Dealer
PostPosted: Wed Jan 12, 2011 12:50 pm    Post subject: Reply with quote
There should be a racor model that fits the Sierra head. You may just have to open some racor units to see which one fits.
PostPosted: Wed Jan 12, 2011 2:17 pm    Post subject: Reply with quote
Racor makes the Honda filters, at least for the size C-Dory gave me. For a lot more info see Honda vs Racor Interchange .
Desolation Cruiser
PostPosted: Wed Jan 12, 2011 4:04 pm    Post subject: Reply with quote
If you get the number off the Sierra filter I can tell you the part number for the Racor Filter & bowl assy. to replace it.
marco422
Photos: Gaiasika
PostPosted: Sun Jan 16, 2011 4:26 pm    Post subject: Reply with quote
The part number for the Sierra filter housing assembly is 18-7986-1.
jennykatz
City/Region: naples
Vessel Name: Little Treasurer
Photos: Jennykatz
PostPosted: Sun Jan 16, 2011 4:44 pm    Post subject: filters Reply with quote
I don't know if I would want a plastic style filter out in the elements might break ,crack with sunlight ,freeze etc
We use the 10 micron blue yamaha fuel filter all metal no plastic never had a problem Once we changed the pickup tubes and started changing filter every 6 months no problems
marco422
Photos: Gaiasika
PostPosted: Mon Jan 17, 2011 12:39 am    Post subject: Reply with quote
I'm having aluminum tanks made and want to move the fuel-water separator to the transom under the splashwell, so sunlight won't be a problem. I'd like to have the see-through bowl so I can see and drain the water if I need to.
bburgin
City/Region: Mississippi
State or Province: MS
Vessel Name: MY HOOKER
Photos: MY HOOKER
PostPosted: Mon Jan 17, 2011 7:55 am    Post subject: filters Reply with quote
go to NAPA they can cross the numbers
Desolation Cruiser
PostPosted: Mon Jan 17, 2011 3:55 pm    Post subject: Reply with quote
My Sierra catalog says the 18-7986-1 is a kit containing one of 18-7775 bracket and one of 18-7945 filter.
You can replace that filter with Racor kit #B32013 which contains one of filter number S3213 and one of Plastic see-thru reusable bowl for outboard engine use only.
I hope this helps.
Page generation time: 0.0314s (PHP: 66% - SQL: 34%) - SQL queries: 28 - GZIP disabled - Debug on
