marco422
Joined: 25 Sep 2008 Posts: 103 City/Region: Salt Spring Island
Vessel Name: Gaiasika
Photos: Gaiasika
Posted: Sun Jan 09, 2011 10:26 pm Post subject: Sierra & Racor cartridges interchangeable? |
Can anyone tell me if the dimensions, threading and design of Racor & Sierra fuel filter elements allow them to be interchangeable? |
Jack in Alaska
Joined: 17 Aug 2004 Posts: 1190 City/Region: Anchorage/Ninilchik
C-Dory Model: 26 Pro Angler
Vessel Name: HIGH TIDE II
Photos: HIGH TIDE II
Posted: Sun Jan 09, 2011 10:36 pm Post subject: |
Also include the Honda filters in that question. |
Desolation Cruiser
Joined: 19 May 2009 Posts: 47 City/Region: Powell River
Posted: Mon Jan 10, 2011 4:01 pm Post subject: |
We sell both brands here.
If you give me some part numbers I should be able to tell you if they are interchangeable. |
mjsiega
State or Province: NY
Posted: Mon Jan 10, 2011 7:59 pm Post subject: |
I've used Mallory and Sierra interchangeably. |
Desolation Cruiser
Posted: Mon Jan 10, 2011 8:31 pm Post subject: |
mjsiega wrote: | I've used Mallory and Sierra interchangeably. |
They both make many different filters and they are definately not all interchangeable. |
Matt Gurnsey Dealer
Joined: 11 Nov 2008 Posts: 1532 City/Region: Port Orchard
Photos: Kitsap Marina
Posted: Tue Jan 11, 2011 12:22 pm Post subject: |
Racor makes a number of different "heads" for their filter assemblies. Some of them are the same as the Sierra. As well as Mercruiser, BRP and others.
I haven't looked at a Honda filter, so don't know for sure. We usually use the Mercury Filter for installations because it is the same as many others, and is reasonable inexpensive for the whole kit. The exception to that would be Yamaha installations because of Yamaha's System Match warranty. _________________ Matt Gurnsey
Kitsap Marina
www.kitsapmarina.com
360-895-2193
(888) 293-7991 |
marco422
Photos: Gaiasika
Posted: Wed Jan 12, 2011 12:01 am Post subject: |
The reason I am asking is that I installed a Sierra fuel-water separator in the splash well last year and have been thinking I would like to have the Racor type I used to have with the clear bowl where you can drain off the water. So I was wondering if I could just install a Racor filter and clear bowl on the Sierra assembly. |
Matt Gurnsey Dealer
Posted: Wed Jan 12, 2011 12:50 pm Post subject: |
There should be a racor model that fits the Sierra head. You may just have to open some racor units to see which one fits. |
Posted: Wed Jan 12, 2011 2:17 pm Post subject: |
Racor makes the Honda filters, at least for the size C-Dory gave me. For a lot more info see Honda vs Racor Interchange .
Boris |
Desolation Cruiser
Posted: Wed Jan 12, 2011 4:04 pm Post subject: |
If you get the number off the Sierra filter I can tell you the part number for the Racor Filter & bowl assy. to replace it. |
marco422
Photos: Gaiasika
Posted: Sun Jan 16, 2011 4:26 pm Post subject: |
The part number for the Sierra filter housing assembly is 18-7986-1. |
jennykatz
Vessel Name: Little Treasurer
Photos: Jennykatz
Posted: Sun Jan 16, 2011 4:44 pm Post subject: filters |
I don't know if I would want a plastic style filter out in the elements might break ,crack with sunlight ,freeze etc
We use the 10 micron blue yamaha fuel filter all metal no plastic never had a problem Once we changed the pickup tubes and started changing filter every 6 months no problems _________________ retired 8/08 from UAL, still working pt tm
marco422
Photos: Gaiasika
Posted: Mon Jan 17, 2011 12:39 am Post subject: |
I'm having aluminum tanks made and want to move the fuel-water separator to the transom under the splashwell, so sunlight won't be a problem. I'd like to have the see-through bowl so I can see and drain the water if I need to. |
bburgin
Joined: 11 Sep 2010 Posts: 64 City/Region: Mississippi
State or Province: MS
Vessel Name: MY HOOKER
Photos: MY HOOKER
Posted: Mon Jan 17, 2011 7:55 am Post subject: filters |
go to NAPA they can cross the numbers |
Desolation Cruiser
Posted: Mon Jan 17, 2011 3:55 pm Post subject: |
marco422 wrote: | The part number for the Sierra filter housing assembly is 18-7986-1. | My Sierra catalog says the 18-7986-1 is a kit containing one of 18-7775 bracket and one of 18-7945 filter.
You can replace that filter with Racor kit #B32013 which contains one of filter number S3213 and one of Plastic see-thru reusable bowl for outboard engine use only.
I hope this helps. |
