Radar question
matt_unique
City/Region: Boston
Vessel Name: Napoleon
Photos: Napoleon
PostPosted: Wed Sep 29, 2010 9:22 am    Post subject: Nice! Reply with quote
Glad to hear it Mike!
Captain Matt
PostPosted: Wed Sep 29, 2010 9:25 am    Post subject: Reply with quote
Yeah, me too. I've got the GPS above the Radar on a pedestal with an aluminum mast about 6" from the radome. Have not seen the problem. It's a 4KW Raymarine.
tpbrady
Vessel Name: Bidarka II
Photos: Bidarka
PostPosted: Thu Sep 30, 2010 12:35 am    Post subject: Reply with quote
I would say Lowrance/SimRad/et al needs to look at that closely. If a mast that close to the antenna generates that type of target, then there is a high probabilty that a real target to the left or right of the mast would me missed. There has to be some way to blank a one or two degree area of the radar equating to the width of the mast to eliminate that echo. Some installations may not have the ability to move the mast.
Tom
22 Cruiser Bidarka 2004-2009
42 Nordic Tug 2015-
28 KingFisher 2009-2014
14 Jetcraft 2000-
17 Scanoe 1981-
Beflyguy
City/Region: Anderson Island
Vessel Name: Seven Please
Photos: Seven Please
PostPosted: Thu Sep 30, 2010 1:14 am    Post subject: Reply with quote
Hi Tom,
I did not try to adjust any settings at all to eliminate the ghosts. My logic in this was that I didn't want to inhibit the definition or sensitivity or limit visibility to any area even aft, if the ghosts were caused by an external mast or other target. I know that some masts, etc cannot be moved and that other solutions would have to be found. I assume there would be alternatives in this case.
Brian
Seven Please
2009 TC255 2010 175 Suzukis
Anderson Island WA
PostPosted: Thu Sep 30, 2010 6:43 pm    Post subject: Reply with quote
Interesting--since conventional wave guide radar would not have caused that interference--even aluminum masts don't on sailboats.
What I am concerned about in your set up, is that it looks as if the GPS antenna is both in the beam of the radar--and is being shadowed by the radar dome--the dome itself is not an issue, but the metal part of the rotating bar is. Lowrance (Navico?) products are very susceptable to radar waves, and many of them have burned out the antennas. I am not sure if Simrad is using the same antenna--but it is very possible. If the antenna is within several feet of the radar, or within a 30 degree beam of the radar, I would move it.
Page generation time: 0.0467s (PHP: 45% - SQL: 55%) - SQL queries: 18 - GZIP disabled - Debug on
