Problem with moving motor up and down
rwatson12830
City/Region: Mardela Springs
State or Province: MD
Vessel Name: Hunter
PostPosted: Sun Aug 22, 2010 10:30 am    Post subject: Problem with moving motor up and down Reply with quote
I have a 1995 Honda 4 cycle on my 22 C-Dory that has about 600 hours on the motor. Sometimes when I raise the motor up high enough to put the locks down, the motor will not go down when you press the down button. Then you have to go to the release presure screw to get the motor back down and if the boat is in the water that screw is hard to get to as it is underwater. I sure would appreciate any suggestions on how to fix this problem. Thank you!
16Pounder
City/Region: Gallipolis
State or Province: OH
C-Dory Year: 1990
Vessel Name: 16Pounder
Photos: 16Pounder
PostPosted: Sun Aug 22, 2010 11:28 am    Post subject: Reply with quote
I had that problem with a Johnson once. Turns out the electrical connection to the switch was loose. If it doesn't make a sound when you hit the down button then my guess would be a loose or corroded switch. If you can get to the connections to the switch and clean/tighten them that might fix it. If not maybe the switch is going bad.
Al
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Sun Aug 22, 2010 5:29 pm    Post subject: Reply with quote
I agree to check the electrical connections first then if needed, test the relays and switches
Brent Barrett
PostPosted: Sun Aug 22, 2010 6:54 pm    Post subject: Reply with quote
Look at it this way. If the hydraulics boosts the motor up and you don't see any fluid, the hydraulics is OK (are OK?)
Referring to the manual for a 2005 150 ( a cheap, handy thing to have for any outboard) it shows that there are two and only two wires to the !@#$ DC pump motor. Thus, the motor is driven in one direction to raise the motor and the DC voltage is reversed to drive the motor in the reverse direction to lower the motor.
Since the motor works in the up direction, you have checked that power is getting through to the motor, and a good bet is that the up/down switch in the throttle is bad. I leave the rest to you.
BrentB
Photos: BrentB
PostPosted: Sun Aug 22, 2010 6:59 pm    Post subject: Reply with quote
good point
m2cw
There are 3 wires going to the tilt switch and check the wire on the down side. It may be bad or disconnected
PostPosted: Sun Aug 22, 2010 7:16 pm    Post subject: Reply with quote
Why would you put the "locks down" if the boat is in the water? I agree that it's an electrical problem. Probably contacts with that many hours on it. Maybe even in the tilt trim switch at the throttle and not in the motor.
kennharriet
City/Region: Grangeville
State or Province: ID
Vessel Name: Lochsa
Photos: Lochsa
PostPosted: Sun Aug 22, 2010 8:10 pm    Post subject: Reply with quote
Does the tilt motor run when you push the down button?
PostPosted: Mon Aug 23, 2010 12:28 am    Post subject: Reply with quote
The trim potentiometer (tilt switch?) has 3 wires going to it. There is ground and positive to provide the voltage reference across a resistor, with the third wire connected to the pot wiper. This gives the position of the trim indicator arm and is only used for the trim indicator.
The tilt hydraulic motor only has 2 wires and is independent of the trim indicator. The throttle switch has relays which reverse the voltage to the motor. The Lewmar windlass is wired the same.
Wefings
Dealer
City/Region: Panhandle
Photos: Cruise Ship #4
PostPosted: Mon Aug 23, 2010 4:35 am    Post subject: Reply with quote
Its probably the relay . BTW The lock is only there to work on the trim motor assembly . It is a common misconception that its for trailering . Its not .A piece of wood or PVC like this Yamaha part is a better way to travel.
Marc
Wefings Marine Website
Since 1909
wapiti
City/Region: sherwood Park
State or Province: AB
Vessel Name: C-Breeze
Photos: C-Breeze
PostPosted: Mon Aug 23, 2010 10:30 am    Post subject: Motor Support Reply with quote
Marc;
I do a lot of trailering of my 22' Angler. What would you recommend as a motor support for my Honda 90 that may be readily available in Canada? Would a piece of solid oak suffice?
Thanks!
wapiti
PostPosted: Mon Aug 23, 2010 10:45 am    Post subject: Reply with quote
Personally, I'd use something a little "softer" like pine. Cheaper, easier to replace and will provide a little "cushion" Oak doesn't give much.
BrentB
Photos: BrentB
PostPosted: Mon Aug 23, 2010 11:05 am    Post subject: Reply with quote
http://www.m-ywedge.com/
This was discussed earlier
jennykatz
City/Region: naples
Vessel Name: Little Treasurer
Photos: Jennykatz
PostPosted: Wed Jan 15, 2014 11:55 pm    Post subject: trim tilt problem Reply with quote
We have a 05-06? f-115 that would not go down with tilt switch .the boat was in the water so I filled up the reservoir best I could in the water and then used release screw on side . The motor came down and we then put engine up and down to bleed the air out and it seems ok . I replaced the 2 trim shock cylinders bushings or rubber gaskets last year but I think it's the center tilt shock that could be leaking so I'm wondering if this can be rebuilt also ? I've gotten conflicting reports depending on year and motor HP??
Page generation time: 0.0488s (PHP: 49% - SQL: 51%) - SQL queries: 26 - GZIP disabled - Debug on
