Best idea under $20
Goto page Previous  1, 2, 3 ... 8, 9, 10 ... 12, 13, 14  Next
marco422
City/Region: Salt Spring Island
Vessel Name: Gaiasika
Photos: Gaiasika
PostPosted: Sun Apr 05, 2009 11:34 pm    Post subject: Reply with quote
Case Logic makes this car seat back caddy that fits the 16 Cruiser seats perfectly. CAD$16 plus a few stainless screws and finishing washers.
http://www.c-brats.com/modules.php?set_albumName=Gaiasika&id=IMG_3760&op=modload&name=gallery&file=index&include=view_photo.php
cemiii
City/Region: Alamo
Photos: The Last One, III
PostPosted: Fri Apr 24, 2009 4:29 pm    Post subject: Reply with quote
I bought a radio adapter fitting that allows you to put your backup handheld VHF (Icom, SH or Uniden, plus others?) on your boats 8' 6db aerial in the event of an electrical or main radio failure. Probably should more than double the handhelds effective range in an emergency situation (though I don’t know how to personally test this).
The fitting is SMA (male) to PL259 (F)
[not all that easy to find but I've seen them all as one]
Alternative is to buy 2 adapters [readily avail] and put them together
BNC (F) to SMA (M) and BNC (M) to PL259 (F)
Parts are often avail on ebay and well under $20,
Keep the fitting taped near the end of your aerial wire and hope it never needs to be used.
Chris
Chris Murphy
Alamo, CA
87 22' Angler 08 Etec 90/07 Johnson 9.9
Byrdman
Photos: FreeByrd and C-Byrd
PostPosted: Fri Apr 24, 2009 4:36 pm    Post subject: Reply with quote
99 cent note pad... nickle #2 pencil.... and a note to myself to turn off the buttons and gizmos that drain my batteries....that cost a bit more than $20.
Now...where did I put that pad and pencil??? Mr. Green
Byrdman
Patrick Byrd "Byrdman"
Miss B - CD22A, Aug 2018
Aloysius, Hull # 440 RF-246
TC24, Hull #51, Sold Feb06
CD16A, Sold Dec03
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Fri Nov 27, 2009 1:30 pm    Post subject: Reply with quote
I have several free small carbiner type clips from meetings and used them to hold box end wrench together. A larger one would be better.
I just replaced the antenna and used a centerpin connector for quick install
$8
http://shakespeare-marine.com/connectorshow.asp?menupick=pl-259-cp-g
Brent Barrett
breausaw
Vessel Name: Triple J
Photos: Triple J
PostPosted: Sun Nov 29, 2009 12:11 am    Post subject: Reply with quote
Piece cut from a 3” PVC union, 99 cents. Allows us to run the Wallas on low at cruise, no more puking exhaust back into the cabin. Hot stick glued as a temporary experiment early this season, still there.
Boatless for now but looking
BrentB
Photos: BrentB
PostPosted: Sun Nov 29, 2009 8:01 pm    Post subject: Reply with quote
I use China wax markers (white, yellow, red, orange) at work and very handy to write on batteries, engines, glass or anything and it is not permanent and easy to remove
One dollar
http://www.bhphotovideo.com/c/product/221888-REG/Berol_BR170T1_China_Marker_Grease_Pencil_Yellow.html
PostPosted: Sat Feb 13, 2010 12:02 pm    Post subject: 3 ft section of foam pipe insulation Reply with quote
I use a 3 ft section of foam pipe insulation to slide over my 8 ft fiberglass VHF antenna when I lay it back for trailering. It then keeps the antenna from bouncing on the cabin roof, and also extends past the top end, to provide visibility and eye protection. A short line wrapped once and then tied to the boarding handle ensures that it is still in place when I am ready to raise the antenna.
See the foam just above the open door and boarding handle in the photo at this link:
http://www.c-brats.com/modules.php?set_albumName=SleepyC&id=SSC_CPR_and_Patient_416&op=modload&name=gallery&file=index&include=view_photo.php
SEA3PO
City/Region: Chester
Vessel Name: SEA3PO
Photos: SEA3PO
PostPosted: Sat Feb 13, 2010 2:07 pm    Post subject: Reply with quote
I just bought "Diary of a Sea Captains Wife" from Amizon for $9.95 for my wife for Valintines Day.... Probably the best money I spent in a long time..
Joel
SEA3PO
DaveS
City/Region: Arlington
Vessel Name: Sea Shift
Photos: Sea Shift
PostPosted: Sat Feb 13, 2010 4:29 pm    Post subject: Reply with quote
Joel
SEA3PO
So Joel, is it a short story that goes something like.......'thank goodness he's finally out to sea' ? Mr. Green
Dave S.
"Sea Shift"
C-Brat #16
BrentB
Photos: BrentB
PostPosted: Wed Apr 07, 2010 8:37 pm    Post subject: Reply with quote
At Walmart, I bought package of assortment of glass barrel type fuses with a nifty tester for $10
toyman
City/Region: Lake Livingston
State or Province: TX
Vessel Name: Fan-C-Dory
PostPosted: Tue Apr 27, 2010 9:58 pm    Post subject: Reply with quote
Here's my best for under $20 - can anyone I.D. them ?
http://picasaweb.google.com/river.rd/CDoryStuff#5465000453199908210
Dave W.
KE5GOH
Stuck in the 70's,
In East Texas
PostPosted: Tue Apr 27, 2010 11:17 pm    Post subject: Reply with quote
I use one on Journey On when camping on land. One end goes into the sink drain and the other end allows one to attach a hose and catch the stuff coming through the sink in a jug.
toyman
PostPosted: Wed Apr 28, 2010 9:19 am    Post subject: Reply with quote
You win 50% of an Attaboy Boris ! Thumbs Up Thumbs Up
The other is for the macerator thru hull. SHE doesn't like holding the hose, and doesn't understand the complexity of one valve and a switch !
PostPosted: Tue Jun 15, 2010 9:34 pm    Post subject: Reply with quote
Getting ready for PNW dungy season. How to store 100 ft or more of 5/16" leaded line? Neutral
Idea From Harbor Freight Tools; extension cord reels. $5/ea.
[img][/img]
Beflyguy
City/Region: Anderson Island
Vessel Name: Seven Please
Photos: Seven Please
PostPosted: Wed Jun 16, 2010 1:14 am    Post subject: Reply with quote
Any Idea of a number for these? I can't seem to find them on the website.
Brian
Seven Please
2009 TC255 2010 175 Suzukis
Anderson Island WA
Page 9 of 14
Page generation time: 0.0521s (PHP: 58% - SQL: 42%) - SQL queries: 28 - GZIP disabled - Debug on
