Remove front window
CTYankee
City/Region: Conn
State or Province: CT
Vessel Name: Crescent Girl
Photos: Crescent Girl
PostPosted: Thu Apr 17, 2008 10:09 pm    Post subject: Remove front window Reply with quote
I have to remove the front opening window on my 22' Cruiser to re-weld the aluminum mounting brackets. I plan to use a heat gun and a lot of patience. Has anyone ever done this? How hard is it and any cautions? Is the window caulked with 3M 4200 or 5200? I guess it makes a difference. Thanks in advance.
Dun (CTYankee)
PostPosted: Fri Apr 18, 2008 12:53 pm    Post subject: Reply with quote
A heat gun and putty knife--possiably a long piece of heated Piano wire, to cut the sealant. I am not sure if 5200 was used, but I suspect not. C dory usually uses "Bostic" sealants...
I have taken ports and windows out of other boats, (not C Dory) using the above technique--if it is 5200, also use the "debond". On one boat I did take a small piece of laminate along with the frame-no problem, just built the area back up with MarineTex.
Mark Toland
Dealer
City/Region: Kent
PostPosted: Fri Apr 18, 2008 1:16 pm    Post subject: Reply with quote
All C-Dorys built by the original company (DOR prefix in serial number) have their windows bedded in silicone. Protect the area around the window with tape and use a thin 1” putty knife. It helps if someone helps by pushing on the inside of the window. Do not cheat and try and pry the window out as that will warp the frame badly.
Mark Toland
CTYankee
City/Region: Conn
PostPosted: Fri Apr 18, 2008 2:01 pm    Post subject: Reply with quote
Thanks Mark and Bob...that is helpful! If it's only silicone, that makes it easier. I'll let you know how I make out.
cemiii
City/Region: Alamo
Photos: The Last One, III
PostPosted: Fri Apr 18, 2008 8:37 pm    Post subject: Reply with quote
opening middle window.........hmmmmm...........another project............
please tell me they aren't available for older boats!
chris
PostPosted: Sat Apr 19, 2008 12:18 pm    Post subject: Reply with quote
chris
http://www.c-brats.com/viewtopic.php?t=8754&highlight=[/url]
Page generation time: 0.0532s (PHP: 43% - SQL: 57%) - SQL queries: 19 - GZIP disabled - Debug on
