For those of you that change your water pump impeller on a Honda BF50, do you also change the 2 water seals in the lower pump housing at the same time? If not, how often do they need to be replaced?
I've done it on Honda 45's. Bought the kit with all seals and did the whole magilla. Once you've got it open, why not? See the OB Motor Forum for diagrams.
