nuccifilms
got a nice mercury 9.8 2-stroke. kicks over on a pull. just that it wasn’t pumping water. replaced the crumbled up impeller and thought problem solved. i believe i got all the old impeller pieces out? all the fins on the new impeller bend nicely, as i rotate the shaft clockwise, key locked nicely in place.
still no water from the pee hole??
i hooked up water supply to the small flush port, an water then shoots right out of the pee hole, so no blockage up top?
i blew into the top tube of the pump housing of the lower unit and i can feel a litter air exiting the intake screen below it., so no blockage in lower unit??
if there’s no blockage anywhere and this new impeller is not pushing water up the tube into the motor and out the pee hole with motor running in water?
these seems to defy logic. what an i missing?
also, i blew into the rubber hose up top, from where the water pees out of the motor, and with the bottom of the outboard submerged in water, air bubbles came out at the screen intake. that’s the complete path, showing no obstructions?
