South of Heaven
- Joined
- Aug 15, 2015
- Messages
- 1,458
- Reaction score
- 0
So, I've been reading a lot of the older threads on here about water intrusion and soft spots....and now I'm freaking out and working myself into a hysteric state!
How prevalent are these problems with our boats?? Is there a direct correlation between keeping the boat in the water and a higher % of water intrusion? Or is a mostly trailer kept boat still as susceptible? Then a step further, does an uncovered boat vs a covered boat have different dynamics? What about geographic locations? Is the PNW more at risk with the rainier/ humid environment? Northeast bad?; because of the cold temps and freeze cycles? Is the ONLY way for water to get inside from a crack, screw hole or damaged area? Or will standing water eventually find it's way inside somehow?
What should I be looking for with my new boat? Is it worth it for me to drain the twin fuel tanks and inspect the floor underneath? What about the V berth area? Anchor locker??
Guys, am I overreacting?? I hope so! I also remember reading that even with most case of water intrusion the affected area is a small radius and USUALLY doesn't spread to a big area. Well, that's a good thing!
