TITAN MODEL 60 BREAK-AWAY LEVER RESET (TRAILER HITCH)
KevinDU
Member
Dec 10, 2010
108
4
2007
22 Cruiser
Sea Otter
I have the Titan Model 60 Surg-O-Matic Actuator for trailer brakes with Multi-Fit coupler and I forgot to unhook the safety chain when I disconnected the trailer from the truck. I need to reset the break-away lever before I can use the trailer again. Has anyone done this before and what is the correct procedure? Pictures would be of great help! Thanks in advance for any suggestions.
I don't know if youv'e already tried this, but from the manual:
Resetting the Break-away Lever is accomplished by first removing the two screws <31> which retain the cover over the break-away spring <13>. This will allow the cover to be lifted. By pulling the break-away lever <10> slightly further forward, you'll be able to pry the break-away spring carefully out of the notch in the outer case <1> to release the break- away lever. When removing the break-away spring, be careful not to deform it.
NOTE: <#> Is the reference number shown in the assembly diagram of the actuator located at the end of this manual.
Here is a link to the entire manual, which has diagrams and drawings that show what they are talking about in the quote above. If you aren't able to download the manual for some reason, let me know and I'll take some screen shots and post them here.
http://titan-intl.com/files/Trailer_Com ... L60_ii.pdf
Got that fixed, thanks Sunbeam!
Sweet! Thanks for posting back that it worked out.
