My recent first outing with my new C-Dory revealed a problem with my fuel tank selector switch. As you can see in the attached photo I don't get fuel when the lever is positioned where the label says I should be getting fuel.
When the pointer is pointing toward "Starboard" I get fuel from the starboard tank. When pointed toward "Port" I get no fuel. I have to point the lever at "Gasoline" to get fuel from the port tank.
The lever will rotate in either direction and there is a slight click as it reaches the dot at off, starboard, port, and the center of gasoline. I haven't pulled the panel in front of the starboard gas tank to get to the actual valve to find a manufacturer's name since it's been raining since I got home with it.
Has anyone else seen this issue? Seems the folks that make the label haven't talked with the folks that make the valve. Do they usually come as a set or are they ordered separate? I can find all sorts of fuel valves online but not the label plate.
