Karl":3skm2cui said:
I ask because there is a long history of whichever factory made the C-Dory, they universally failed to properly seal penetrations, by under-cutting all holes and filling edges with epoxy, then re-drilling.
That is true, but... it could also be said of just about every other production boat builder. I'm not saying that thrills me, but unless you go semi-custom that seems to be the way it is (maybe there are exceptions).
4200/5200 bedding is not equivalent to epoxy-sealing the edges of a cored penetration...even if a proper install adds $500 to the cost of a new boat.
I've done most of the core penetrations on my boat. Granted, it would be a lot faster and easier to do it from the start (for example, don't even put coring where trim tab planes will be mounted - just make that solid fiberglass) vs. re-doing everything (and yes, I have muttered a few choice words while suited up and making dust), but... I can't imagine it adding anywhere near to only $500. Materials, labor..... it would be thousands. I would pay it
gladly, but apparently most people would just move on to a more "competitively priced" boat. Or at least that is my guess as to why production boats are still built the way they are.
I bought a second-hand boat, partly becuase yeah, taking a brand new one apart would be aggravating (and having had to re-core several boats, I can't relax until I do the overdrill/fill). That said, they don't rot instantly, so one could buy a new boat and then when the time came to re-bed the fittings (as it always will, even if they are properly closed out) do the "routine."
I passed up a few foam-cored boats that had serious de-bonding issues (i.e. the skins and core had separated) (not C-Dorys). In a Bruce Pfund workshop on composite techniques, he did a demo showing a method for "encouraging" the foam to bond better to the skins, so it seems to be a little bit more of a challenge in that way than balsa. I don't see foam as a magic bullet -- it has its good and bad points, as does balsa. Care and proper build techniques are key.
I'd love to hear what the current C-Dory builders have changed, and what they've kept the same. It's always interesting to know how boats are built, and how things evolve.
