When I came back into Whittier today after the last trip of the season, I put the motor in reverse to find nothing happens. Fortunately I wasn't going to fast and was able to dock without any problems. As soon as I looked at the lower unit, the problem was obvious. We were lucky in that the water was clear and about 9 feet down you could clearly see a stainless prop.
We had just covered about 75 miles from Green Island and had put the motor in reverse the night before when setting the anchor. I visually inspect the prop each time before I launch for security. I was using the Honda retaining clip and three of the tabs were least 1/8 inch below the retaining ring. The motor had at least 300 miles on it since the prop was last removed. The question is what failed. I don't see three tabs breaking at the same time. The nut can't back off if the tabs are depressed. Since the Quicksilver prop uses an insert for the Honda spline, my initial guess is the retaining ring separated from the insert.
Has anybody heard of this happening before? By the way, it was quite a chore to lasso a prop in 10 feet of water with a rising tide. Thanks to some duct tape used to attach an oar to a boat hook we got a loop around two of the blades and the hub (we used a 2 lb halibut weight to get the rope to the bottom).
