I found that my port engine's prop had suffered a hit that bent 2 of 3 blades, one has a small crack as well, so I went to order new props. I could not find an exact replacement (11.25 x 13) so I went with 2 Solas that were listed as 11- ?/5ths X 13. Can't remember the "5th's" but I mistakenly calculated them as 11.20 diameter....they are actually 11.62 diameter. I have plenty of clearance to run them on my Honda 45's, just wondering what the slightly larger diameter will do. I assume that it will knock down my WOT slightly if anything (was a max of 5900-6000 previously). Would those in the know agree?
