joeC
- Joined
- Nov 8, 2005
- Messages
- 39
- Reaction score
- 0
- C Dory Year
- 2005
- C Dory Model
- 22 Cruiser
- Hull Identification Number
- cd0255131506
The Coleman Mach Ac system I installed works great. I now have over 100 hours on it and in the evening it will freeze the house on the Tomcat. Honda's 3000 inverter gen will run for about 12 hours pulling the Ac in economy mode on 3 gallons. At night on low the cabin will pull down to where you need a blanket fast. In houston it can also be 90F at night so no Ac no way. If I adjust the thermostat on the coleman up at night the honda has to be in normal mode instead of economy or the compressor will not start so I just leave it turned down. Also I did install a CO monitor in the cabin which I purchased at West Marine for to much almost a hundred bucks Walmart has same thing for 17 bucks. It is very advisable for all these cabin boats to have CO monitors we have had it go off trolling with the rear door and front window open and only outboards running. When I was thinking about this AC project I almost went with a 7000Btu unit but I found it would not the job on these hot summer days. The 13500 Btu unit grunts pretty hard in the hot sun and I normally see about a 20 degree drop from ambient temp. In the boat I added another panel for the Generator input and installed a large GFI to try and keep it all safe, saltwater and 125 volts do not mix well.
