Mr. Fisherman
Well I finally got all the parts and plan to install my kicker bracket this weekend.
Should I mount it in the same area I had it on my transom?
If so how do I go about getting the depth and alignment of the kicker right? I thought that if I keep it in the same left to right alignment and adjusted the depth (up, down) so the prop is in the same depth it is when it is on the transom it should be fine. My concerns are the clearance of my main motor when I turn hard over and the connection to my EZ steer via the steering rod.
I don't want to drill 4 holes more than one time. I am also concerned about placing the kicker on the bracket and holding it up with clamps but I may have to try it. Maybe it won't be bad. The durn thing is pretty heavy being as it is a 4 stroke.
