I finally installed the M120 trim tabs. Haven't tried them yet. Need to fab the kicker mount that I believe was drawn up by Tyboo. Local machinist is looking for a peice of 1/8 inch stainless. Will this be thick enough? Any recommendations on material? My kicker is a yamaha 4 stroke 15H.P. It weighs 100lbs. In search of a backing (mount) plate material also.
Note: When I removed the kicker from the transom I was suprised to see four nice slits punched clear thru the gel-coat. The inside of the engine mount bracket has nice tiny little grippers that cut right into the glass. The engine fit so tight over the transom that no room was available for a pad.
