Hi Folks,
Last time I winterized my Honda 90 I made notes detailing the process. Those notes are posted here:
Winterize Honda 90
Oil 10W30 4.2 Qts without filter
Filter Part# 154000-PLM-A01 fits 75 thru 225 was $9.95
Lower unit gear oil
Racor filter
In line fuel filter
Spark Plugs NGK # 98069-5771P
Fogging oil
Small funnel and hose fuel container
Gear oil pump
Top off tanks and add fuel preservative.
Attach Muffs
Run engine to warm oil
Shut fuel off
Run until engine starves off
Drop cloth below lower unit
Catch pan
10&12 mm sockets plus extension
Water bottle with bottom cut out and semi circle opening at top and string tied to neck of bottle
Open drain plug access 10mm
Attach bottle with string by wrapping string once around lower unit so that the bottle remains in position to catch and direct the waste oil into the catch pan
Access drain plug from semi circle in bottle
Remove drain plug and direct fast moving stream of oil into pan
Lift dipstick to open vacuum
Remove spark plugs
Fog cylinders
With plugs out manually spin engine with lanyard
Replace old plugs
Once all oil is drained from engine -replace and tighten drain plug
Tilt engine to max horizontal
Tuck rag under oil filter
Use filter wrench to remove oil filter
Lube new rubber seal, lube threads, clean seat and screw on new filter, and tighten as prescribed on canister
Lower engine to vertical position
Fill engine with 4.2 quarts of 10W30 oil then check to top off
Place catch pan under lower unit
Remove lower unit gear oil inspection port
Check for water
Remove lower unit drain screw
Allow to drain
Check for metal filings in drain oil and on magnetized drain screw
Once all oil has drained from lower unit
Insert filler end of gear oil tube into drain screw opening and squeeze contents of tube into lower unit until it begins to flow out inspection port. Or use pump to pump fresh oil into lower unit.
Thread inspection screw into inspection port while keeping pressure on gear oil tube. Quickly remove tube from drain screw hole and immediately replace drain screw. Check both lower unit screws for proper tightness.
Remove stainless cotter pin from prop, remove castle nut and washer just inboard from castle nut then remove prop. Clean prop shaft and hub. Grease with water resistant grease. Replace prop, washer, castle nut and new cotter pin.
Drain Racor fuel filter and water separator
Using filter wrench, remove filter and water separator chamber together
Remove water separator chamber from disposable filter cartridge
Lubricate plastic threads on chamber and thread onto new filter
Screw combined unit onto Racor body
Remove inline fuel filter for cleaning or replacement
Clean or replace inline fuel filter
Loosen each carburetor drain screw and catch drained fuel in absorbent cloth, retighten screws. Spray WD 40 on power head. Replace engine cover.
Grease zert fittings on lower unit and clean old grease as it squeezes out from joints.
Use helm to turn engine completely to expose steering cable shaft. Clean shaft with WD40. Repeat process until certain of cleanliness. Grease exposed shaft with waterproof grease.
Apply waterproof grease to power tilt shafts.
Disconnect and remove batteries. Clean terminals, place on a wooden pallet in basement and slowly charge to max.
Clean up and wait till spring.
Winterize Honda 90
Lower unit gear oil
Racor filter
In line fuel filter
Fogging oil
Gear oil pump
Attach Muffs
Shut fuel off
Catch pan
Remove spark plugs
Fog cylinders
Replace old plugs
Check for water
Allow to drain
