Alyssa Jean
This is my 2005 25. About a month ago I noticed a slight gasoline smell in the cabin. After looking all through the area under the cockpit in the aft section I found an accumulation of about a 1/2 C of gas around the bilge pump depression. Cleaned it out and looked everywhere I could look to find the source. I removed both of the 8" round inspection hatches under the cockpit step and can see both the fill and vent hose connections which are all double clamped with no sign of a leak. I looked at the inspection hatch at the center of the cockpit floor and can see both the fittings and hose connections for the two gas lines which run over the top of the tank to the aft. I checked all the hoses, fittings, water sparator, etc and see nothing. This is leading me to think that the aluminum tank has developed a pinhole leak somewhere. All the fittings on the tank come through the top so they can't leak unless the tank is filled completely to the top and into the fill hoses.
Anyone ever had a problem like this? The next thing will be to pull the floor panel I suppose.
