Hello All,
Last week I experienced a fuel delivery problem with on my boat such that I could run my Honda 135 at no more than 2000 rpm otherwise the engine would sputter/stall as if out of gas. I'm neither a savvy nor experienced boater. This turned out to be a learning experience for my family and me. Maybe someone else can avoid a problem such as this...
This was the scenario: We boated approx 30 miles through ICW and other 12 miles around St Joe Bay without trouble. We cruised at least half that time at 4000 rpm. We departed Port St. Joe Marina for home (Apalachicola) on a low port tank; my intention was to switch to the full stb tank en route. Approx 5 miles into the trip home, the engine sputtered as if out of gas. This was anticipated; I switched the fuel selector to stb tank (as I had done many times in the year I've owned this boat) and we cruised on....for about a minute. Then the engine began to sputter/hesitate as if starving for fuel. I squeezed the fuel bulb; after 2 squeezes it stayed flat. I triple-checked the proper orientation of the fuel selector valve. If I switched the fuel selector back to the empty port tank, the fuel bulb immediately re-inflated. It appeared there was a problem with delivery of fuel from stb tank to engine....
I drained the fuel filter from that clear bowl at the bottom of the separator/filter...no water but a few specks of dark material. Fuel filter was last changed in April 2009 about 20 engine hours ago. The fuel filter element and bowl assembly was tight - no air leaks. After a while I got out my spare fuel filter and changed that without improvement in the engine's ability to exceed approx 2000 rpm.
We limped home making 8-10 mph...depending on the current. As long as I didn't get in a hurry and exceed roughly 2000 rpm, the engine ran fine.
NEXT DAY: At Wefings, the mechanic diagnosed the problem as a faulty fuel pick up in the stb tank. Upon removal, the pickup consisted of an semi-rigid piece of white plastic tubing with a slight kink or bend in it. The distal end of the pick up tube was cut at 90 degrees and appeared to suffer from flow restriction due to being flat against the bottom of the fuel tank. The pick up tube was cut an 45 degrees and re-assembled. I took the boat home and pulled the (still empty) port tank which showed the same 90 degree cut fuel pick up tube but lacked a tell-tale bow. I cut it an 45 degree as well.
Boat now runs fine.
Has anyone run into fuel tank pick problems causing lack of fuel delivery to the engine/s? Does anyone routinely pull their fuel pickups to make sure something like this is not likely to happen (i.e., no 90 degree cut tubes stuck up against the bottom of the tank thereby causing a fuel restriction/obstruction)? This was all new to me.
/david
Boat now runs fine.
/david
