Frsh Water Rinse for Honda 40 Twins
tejohnsrude
Jul 12, 2006
25
2006
22 Cruiser
Hull Identification Number
CD022382F505
Darlene Mae
My boat is in the water all the time. Salt water. Honda says the engines should have a fresh water rinse each time it used. How in heck can that be done without hauling the boat out each time? Is there some attachment somewhere that I am unaware of? Help!!
Ted
There should be a fitting available from Honda that will screw into the block by the thermostat housing. You would then simply take off the engine cover. screw in the housing, hook up the hose and flush it with fresh water.
Maybe I'm missing something with regard to how that engine flush feed-bag works! I guess you fill it with fresh water, start the engine and then constantly replenish whatever overflows using the hose. With the engine cooling water intake in very close proximity to the cooling water discharge, wouldn't it take a very long time and use a great volume of water to displace the salt water with fresh water?
Paul K
Paul,
You hit it on the nose.
What I like about the flush bag is that you don't risk ruining the impeller by using a set of muffs. On the Honda 8 in the photo, I burned up the impeller after a grand total of about 15 hours on the engine. I don't know if the water pressure was too much/little, but it started squealing after about 3 minutes of operation. The owners manual recommends never using muffs.
Hence the flush bag. Just make sure that you measure correctly and let Quality Marine know if you have a permatrim plate.
Steve
the Honda 150's have a little hose fitting just under the engine lid into which youi run water while the engines are NOT running. I guess this rinses all but the bottom of the leg.
Thanks guys! I think I'll give the flushing bag a try if my boat ever gets built. I'll just have to keep an eye out for the "water police".
Paul K
I spoke with a Honda dealer in Seattle and he said there was no way he knew of that the engine could be flushed while in the water. He was unaware of any fitting as you mentioned. Perehaps he is ill-informed. Will try to reach a factory service rep.
Thank you for your suggestion. Much appreciated
Ted
I had the fitting installed on my Honda 50. It had a hose that excited from under the engine cowling that you attached a garden hose to. very convenient. I had it done at Big Boys Play Toys 386-328-4510. Might give them a call to find out more.
Ted,
You can read the Honda owner's manual for your particular engines on the Honda site. My owner's manual describes the hose fittings for the 135 and 150 Honda outboards.
You can search for the Honda site and read your manual. It works better if you have the engine no.s , etc., but they still let you read manuals in general.
Without the serial and model no.s you may get misinformation.
On the Hunky Dory I had twin 40's. I ordered a small brass fitting that screws onto the lower unit when in the water or on land. The engines must be up in the water untill hooked up. You don't run the engines, just wait for the water to pee out of the upper unit. I never actualy done it when on a mooring because we had no running water. I wonder if a guy could use the wash down hose....... I don't see why not. Funny Honda didn't tell you that. It is a Honda product.
captd
I have attempted to use flushing bags to flush Honda t-40's while the boat is moored in saltwater. Sorry to report that it's a real pain in the neck. It can be done but IMHO is not worth the hassle and possible danger. You have to climb into the motor well and "lasso" the flush bag around the lower unit with the motor up. Then you lower the motor and simultaneously begin filling the bag with fresh water (and a splash of salt away to make things go quicker. Once you lower the motor low enough to safely run it you start it up, flush, then raise the motor, timing the removal of the b ag with the lower unit clearing the saltwater body. It's as complicated as it sounds. If you spill any salt away in the splashwell you're walking on a very slick surface. I'll keep the bag for trailer flushing but keep looking for a credible fitting for an easier flush. Mike.
Mike,
Honda makes a good fitting for flushing the engines, you just can't run the engines while doing so. I am not certain how complete it it compared to having the lower unit in fresh water, but it can't be that bad.
BTW, I have both a flush bag and fittings for each of the Honda's (90 and 8), but prefer to have the lower unit in fresh water when ever I can.
Regards,
Steve
