Fresh water wash down made simple
drbridge
A few weeks ago someone was looking for a way to flush their motor using fresh water tank. This is the set up that we use. I installed a Whale brand foot water pump a few years ago
https://www.whalepumps.com/marine/produ ... t-operated
It is a double diagram pump and pumps on both the down stroke and up stroke. Pumps about as fast as an electric pump if you want to. Takes a little getting use to but it also eliminates the rubbery taste from the original rubber foot pump.
Then I got a length of 3/8 inside diameter tubeing and put a male hose end connection on one end and on the other I heated up the tubing a little and slid it over the sink faucet. You can use this to flush and spray down the motor. I can also use it for cleaning and filleting fish. Susan stays in the cabin and pumps water for me when I ask her to.
I had installed an electric wash down pump and it worked good but it emptied the tank really fast so I didn't use it and ended up taking it out to save space. This set up is much simpler. It can also be used to siphon the water out of your tank at the end of the season. Just throw the hose over the side of the boat and pump it until water starts running out of it and the rest will siphon. Caution should be taken to disconnect the hose from the faucet as soon as you get done with it to avoid any possible backflow
Great idea!
This would have been very handy in many situations over the years.
Nice to see the double action Whale pump alternative too. I was not aware of them, I am still using the single action one that came with the boat, 24 years now.
My electric wash down pump does 5.5 gallons a minute. This dual action diaphragm foot pump does 4 gal per minute and fits in the same place as the original rubber pump. It is not comparable to the standard rubber foot pump in performance.
