rjmcnabb
- Joined
- Sep 1, 2007
- Messages
- 159
- Reaction score
- 0
- C Dory Year
- 1999
- C Dory Model
- 16 Cruiser
- Vessel Name
- Luna
I want to install an external socket in the cockpit so I can plug Luna into 110V shore power. The trouble comes when I have a hole made (about 3cm) and no way to get behind it. The places I might use are all out of reach to me unless I want to remove about all the interior liner from that side of the boat. The liner that covers foam flotation (and the electrical chase) in the cockpit side also enters the cabin to provide side wall covering in the cabin and form the cabinet for the seat mount on that side. It is one bodacious molding and there is no way I am ever going to take that loose.
I will have the same problem when I try to install any fixtures on the coamings: how do I get in there to place washers, nuts, backing plates, etc??
8) The only solution I see right now would be to install a large inspection port at some central place, then remove the flotation behind so that I can get to the back of the liner and the coaming. That might mean a couple of inspection ports per side. Help! Please? :idea
Thanks, Rod
Thanks, Rod
