Ahemmm, John, You are right about the 30 feet thing. I tried to do that but I ran out of boat. My banker said I didn't need to buy a bigger boat, so I just used my 22 Cruiser, and You are right. It Works. 8) and the banker didn't fire me. (Maybe Marconi meant 30 feet UP :lol:
Actually, there are some guidelines about how close you can install one VHF antenna to another VHF antenna. Hummm, I ran out of boat going those directions too. (Too many radios, not enough roof acreage I guess :shock:
Seriously, I have not heard about any particular distance radio to antenna. BUT you do not want to cut the Coax cord too short. I think it has a specific minimum length which I believe is 6 feet.
As you can see, I have 3 VHF's all side by side, and 3 VHF antennas on the top, plus there is an AIS active transceiver running full time as well. (The AIS shares one VHF antenna with one of the VHFs.) Yup, some folks think it is too many radio's, I just think the roof is too small, but the boat is just the right size.
What makes some difference is where the antenna is mounted. Height is you friend there, so as high as you can get it is good. The higher the better, so for me, that means mount on the top. The side mounts are too low and they will get in your way when you are on the walk-around.
If I had a radar arch they would be up there. Still hard to get 4 feet between, (which is HIGHLY recommended), but so far, after a dozen years, no issues.
SleepyC :moon
