One of my wheels spins easily in the forward direction but not in reverse. In reverse, it binds and cannot be rotated without significant effort. The inside brake pad is causing it to bind and I see that the pad has some play in it. The movement is lateral to the rotor, not in and out (perpendicular) to the rotor. I can move the pad a little by hand and that frees up the wheel to spin, but only when I hold it just so. Is there a way to adjust the pads so that there is not this contact with the rotor, short of removing and disassembling the caliper? I have non-vented tie down disc brakes.
