When Carl at EQ was installing the Honda BF15 kicker, we noticed that the boot where all the control cables and the fuel line go through the side of the motor well was toast - really disintegrating, apparently it is rubber and UV has taken its toll. Has anybody else replaced the boot? First off, West Marine only had boots that had four screw holes, this has six. Then, the "correct" way to replace it would be to disconnect all the cables, slide the boot over them, screw the boot in place and reconnect all the cables - not for the faint of heart! Les suggested just cutting a slit in the boot and using clamps - he also said there might be vinyl boots that would last longer than the rubber boots, but we have not found one yet - have not done any extensive internet research yet though. I wonder if this is another "epidemic" that all you 2004 - 2005 CD25 owners will now start noticing on your boats...
