Don't get me wrong, ve love that boat but we have sure had to re do plenty of things on er.
For some times ve have noticed 3 to 4 gallon of water in the bilge after a 3 to5 day trip. Finally getting off my arse and envestagating I found the following. Scupper ports are not even close to the same hight. One is 7/8 inch higher than the other one, causing me to effectivly have only one scupper. ( based on water line) Port is also 1/2 inch higher than the recess which always leaves lots of water in this area. Scuppers are of very poor quality to begin with and applied directly to the back of 14 degree transom they want to hang open all the time, further causing the problem.
Now for the good news and fix. After rasping everything to bare wood / glass I discover that when floor of back deck is put in it only comes CLOSE to transom, so factory just fills void (3/4 inch) with silicone. Well, in times it pulls apart or never had good seal in the begining.
After sealing all and bridging gap with 3 layers on 6 oz cloth and rosin, ve then used brass 1 1/2 sink drain pipe cut to fill in hole well and sealed all with Marine tex. Now it is solid and no mess to clean any more too.
Oh yea, the scuppers! Skifkits in Anchorage Ak (maker of Tolman skiffs) sells a wonderful scupper complete with angled mount block which now lets rubber thingy hang square to earth. They said their rubber would also work better in cold water than factory c-dory flapper. Heading out Monday and expecting better things!
Martin
Martin
