C-Brats
We have launched and loaded a TomCat probably in as many varied locations as anyone, except maybe Fred Kistler. The TomCat 24 usually required a crew of two, and occasonally more. The condition and steepness of the ramp was the big factor.
On flat ramps it is difficult to get the boat to float off, due to the height of the boat on the trailer. You end up powering off after backing in as far as you dare. Then you power on when loading. On steep ramps the issue was that the anchor would foul on the bow stop and you would have to go forward and unhook it.
The design of the EZ Loader trailer on the TC24 was poor at best. I ended up making a center guide-on to keep the boat lined up during launches, but more importantly during loading. The included factory guide-on's would simply bend over in any kind of side wind. Also the trailer was out of sight, being completly submerged. I extended the side guides and beefed them up. See the Cygnet album on both C-Dogs and C-Brats. Byrdman's thoughts on using dock lines to help guide the boat on, were also our experience. That's where more crew was appreciated. I did have EZ Loader make a split bow stop, which helped in keeping the anchor off the bow stop.
We were always able to eventually get the TC24 off and then back on the trailer. It was just not easy. Once at Puerto San Carlos on Magdalena Bay in Baja Mexico, we beach launched the TC24, over the sand, with a mexican friend's, Ford Victoria Taxi. I have a picture of this , and will post it if I can find it.
The only time we have launched and loaded the new TC255, was at Lake Washington. The ramp was very flat, and we experienced much the same problems as with the TC24. The boat would not float off the trailer. When we tried to power off, the anchor hooked on the bow stop. We powered back forward and let out the anchor windless, then laid the anchor (Bruce 22 lb) on the deck, and powered off again. Loading was the reverse process. As Bob Cat has mentioned we have electric/hydraulic brakes. The accuator is mounted on the trailer tongue, and would not let us back the trailer in far enough to float off, without getting the accuator wet.
I have contacted the EZ Loader Rep. Tim Egan, and he is working on resolving these problems. I am confident that the new TC255 trailer can be reengineered to solve these issues. It's a great trailer down the road. Pulls fine and handles the TC255 with ease. Have to look back to know the boat's back there. Just heavier than the TC24 up the hills, and the electric accuator is a little slower to begin braking, than with surge brakes.
We pulled the TC24 for over 30,000 miles over all types of roads, with only one flat tire, and no other problems. We hope to do even more miles with the new TC255. Living in Utah, it's a long trip to the ocean no matter where you go. Still it's a great way to spend our time during retirement.
Brent
TC255
