Stern Thruster quit
capnruss
City/Region: Largo
C-Dory Model: R-25 Tug
Vessel Name: Popeye
PostPosted: Mon Aug 04, 2008 11:09 am    Post subject: Stern Thruster quit Reply with quote
I have an R25 and this weekend the stern truster quit. It's not a shear pin, the motor doesn't run at all. The front one still works fine. I did find a blown 7.5 amp fuse blown in the battery compartment but I didn't have any replacements with me. I don't know if thats the problem or not but would like some help with this. Thanks, Capn Russ
terraplane
City/Region: chesapeake bay
Vessel Name: BANJO
Photos: Sally's Sister
PostPosted: Mon Aug 04, 2008 1:33 pm    Post subject: stern thruster Reply with quote
Two weeks ago my stern thruster on my R25 quit. In my case, we hauled her out and found the whole apparatus, cowling, tube, etc, encrusted with barnacles...so much so that the hole was almost closed up.
Probably not your problem but worth checking.
Wefings
Dealer
City/Region: Panhandle
Photos: Cruise Ship #4
PostPosted: Mon Aug 04, 2008 3:20 pm    Post subject: Reply with quote
Capn Russ has figured it out . New fusible link on the way......
Marc
Wefings Marine Website
Since 1909
capnruss
City/Region: Largo
Vessel Name: Popeye
PostPosted: Tue Aug 12, 2008 8:17 pm    Post subject: Stern thruster Reply with quote
Ok, I fixed the thruster fuse that was blown. Now the thruster clicks (solenoid clicks) that is but the thruster does not run. The fuse is holding but no thruster. I checked the voltage at the thruster and it only drops a few tenths from 13.3 to 13.1 volts. This boat is a 2007, I've owned it for about a month and so far I have had a blown fuse on the thruster (fixed) now the thruster doesn't work. It has to be something internal to the thruster. I have had a bilge pump fail. The autopilot has stopped working consistantly. This, in my opinion is not good for a boat that's not even 2 yrs old. Perhaps I bought a lemon. Everyone else seems to love these boats. Not such a good start for me.
TomRay
Dealer
City/Region: Punta Gorda
PostPosted: Tue Aug 12, 2008 9:01 pm    Post subject: Reply with quote
Sorry to hear of your problems, Russ. Have you checked for barnacles? I would think that if barnacles (or anything else) prevented the shaft from turning, the fuse would blow again. Still worth checking whether or not it will turn if you push the blade with a tool.
I was recently part of a prolonged exorcism on an autopilot (Raymarine product on a sailboat). After lots of setting and recalibrating, we found a source of interference near the compass. With that removed, problems remained. Software was upgraded, and problems continued. Finally the brain and compass were replaced, and all seems OK.
I read the other day (in Lats and Atts?) about a new type of bilge pump float switch which may replace the mercury ones common in most boats.
Gulf Island Sails
mikeporterinmd
State or Province: MD
Vessel Name: Shelly IV
Photos: Shelly-IV
PostPosted: Tue Aug 12, 2008 10:49 pm    Post subject: Reply with quote
Waterwitch switches are great. They are electronic sensor based. It is a
block of epoxy with two silver washers exposed ad three wires coming
out. I have mine set so just about every last drop gets sucked up.
Mike
terraplane
Vessel Name: BANJO
PostPosted: Wed Aug 13, 2008 12:59 am    Post subject: My stern thruster problem Reply with quote
My problem was barnacles...it was full of them.
Complicated by the fact that they did not put proper paint on the assembly when it was installed.
tom
capnruss
City/Region: Largo
Vessel Name: Popeye
PostPosted: Wed Aug 13, 2008 9:28 am    Post subject: Reply with quote
Yes there were some barnicles and I cleaned the units as good as I could. The prop on the thruster is free to turn by hand. The fuse is holding. I'm pretty sure the problem is in the thruster. Thanks for any and all help and suggestions.
SGIRhino
Dealer
City/Region: Eastpoint
PostPosted: Wed Aug 13, 2008 10:25 am    Post subject: Thrusters Reply with quote
Good Morning Russ,
Sorry to hear about your thruster and A/P problems. I'm sending a message to your email, as always we are here to do whatever necessary to make your boat right and your ownership experience a pleasant one.
Charlie Holtom,
Wefing's Marine, Inc.
It ain't a Hobby and it's not Mission Work...it's a PASSION!!!
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
captd
City/Region: Chain of Lakes
State or Province: MT
C-Dory Year: 1994
Vessel Name: Kon Tiki
Photos: Hunky Dory
PostPosted: Tue Aug 19, 2008 7:41 pm    Post subject: Reply with quote
Russ,
check to see if the hinges on the over heads effect the flux gate. Tv might also be the culprit. I had trouble setting track .
Sorry for all your problems.
Maybe I can meet you guys down there this winter.
captd
100 ton Master
capnruss
City/Region: Largo
Vessel Name: Popeye
PostPosted: Wed Aug 20, 2008 6:47 pm    Post subject: Re: problems Reply with quote
Thanks for your help capt d. I took it out this past weekend and the autopilot worked just fine. before that I found a 7.5 amp fuse in the battery compartment that was blown and I replaced it. I don't know what it's for but that may have been what fixed the problem? I really don't know but it worked ok this time. If you know what that fuse is for please let me know. It's a spade type automotive fuse.[/i]
Page generation time: 0.0467s (PHP: 44% - SQL: 56%) - SQL queries: 24 - GZIP disabled - Debug on
