harryr2000
Posted: Thu Mar 06, 2008 8:01 pm Post subject: Wallas Stove - Purchase One? |
If you are buying a used boat without a Wallas, could you buy one and retrofit, how much might it cost?
Thanks!! |
Wandering Sagebrush
Joined: 21 Jan 2005 Posts: 2783 City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
Posted: Thu Mar 06, 2008 8:21 pm Post subject: Wallas |
Yes, I think I would retrofit to a Wallas, and they cost too dogon much!!!
You might contact a dealer like Les at EQ and see if he can make you a deal. I know that there is some markup.
An alternative might be a butane stove on the counter top, plus a small heater like a force 10. I think several folks have that combination.
Steve |
Ron on Meander
Joined: 17 Jun 2004 Posts: 561 City/Region: Powell River
Vessel Name: Meander
Photos: Meander
Posted: Thu Mar 06, 2008 8:25 pm Post subject: |
For sure you could. If I remember correctly the boat show pricing was about $2300 for a kit. Its a relatively straight forward job if you don't mind cutting a two inch hole in the side of your boat.
I really like the wallas. I personally would not trade it for propane or for one of the butane cookers as some people have done. In fact, I've got a wallas 1800 heater on order that I will be installing in the next month or so. I'm going to have one "hot" boat when I get both of them going.
Ron |
Posted: Thu Mar 06, 2008 8:30 pm Post subject: |
Scan Marine is the US distributer:
http://www.scanmarineusa.com/wallas_stoves.html
I don't know how much they are in the US--but judging by UK prices which are on the web (at about 1000 lbs)--it will be somewhere North of $1500. Occasionally used onces show up.
Toyo also makes a similar stove.
The install is fairly simple--cuting the area for the burners, the hole in the hull, ventillation slot and mounting the fuel tank, and hooking up the wire directly to the battery. Probably a day's work. _________________ Bob Austin
Rob & Karen
State or Province: TN
Vessel Name: Life of Riley
Photos: Life of Riley
Posted: Thu Mar 06, 2008 9:14 pm Post subject: |
As Ron mentioned, you could also keep the existing stove and add a Wallas heater. There are several too choose from. We added the 1300 to our CD22 and are very happy with it.
http://www.scanmarineusa.com/wallas_furnaces.html
Rob |
tsturm
Joined: 01 Nov 2003 Posts: 1172 City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
Posted: Thu Mar 06, 2008 9:47 pm Post subject: Re: Wallas Stove - Purchase One? |
harryr2000 wrote: | If you are buying a used boat without a Wallas, could you buy one and retrofit, how much might it cost?
Thanks!! |
I did just that last fall (picts in JMR II album) $2340.00 |
mpmccoy
Joined: 19 Jul 2007 Posts: 65 City/Region: La Habra Heights
Vessel Name: Sea Queen
Photos: Sea Queen
Posted: Fri Mar 07, 2008 1:27 am Post subject: |
Bought mine from Scan Marine. Great support...easy to install. See all the pictures of the install in SeaQueen Album
Other's have documented their installs also.
I wouldn't be without the Wallas. _________________ Sea-Ya |
C-Hawk
Joined: 02 Nov 2003 Posts: 2150 City/Region: Carpinteria / Channel Islands
Vessel Name: C-Hawk
Photos: C-Hawk
Posted: Fri Mar 07, 2008 9:33 am Post subject: |
Fishtales had the Origo stove (an ok stove for cooking), but I had a Wallas installed.
So - to answer your question--- Yes you can add a Wallas after market.
If you have the Origo, you will need to retrofit for the Wallas. The Origo is larger than the Wallas and you will need to fill in around the counter. _________________ Roger
2008- CD22- "C-Hawk" Sold
KJ6VVB
A Brat I am, At sea I be
God is Great, Beer is Good.... and People are Crazy |
