Wallas Stove - Purchase One?
harryr2000
City/Region: Edenton
PostPosted: Thu Mar 06, 2008 8:01 pm    Post subject: Wallas Stove - Purchase One? Reply with quote
If you are buying a used boat without a Wallas, could you buy one and retrofit, how much might it cost?
Thanks!!
Wandering Sagebrush
City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
PostPosted: Thu Mar 06, 2008 8:21 pm    Post subject: Wallas Reply with quote
Yes, I think I would retrofit to a Wallas, and they cost too dogon much!!!
You might contact a dealer like Les at EQ and see if he can make you a deal. I know that there is some markup.
An alternative might be a butane stove on the counter top, plus a small heater like a force 10. I think several folks have that combination.
Steve
Ron on Meander
City/Region: Powell River
Vessel Name: Meander
Photos: Meander
PostPosted: Thu Mar 06, 2008 8:25 pm    Post subject: Reply with quote
For sure you could. If I remember correctly the boat show pricing was about $2300 for a kit. Its a relatively straight forward job if you don't mind cutting a two inch hole in the side of your boat.
I really like the wallas. I personally would not trade it for propane or for one of the butane cookers as some people have done. In fact, I've got a wallas 1800 heater on order that I will be installing in the next month or so. I'm going to have one "hot" boat when I get both of them going.
Ron
PostPosted: Thu Mar 06, 2008 8:30 pm    Post subject: Reply with quote
Scan Marine is the US distributer:
http://www.scanmarineusa.com/wallas_stoves.html
I don't know how much they are in the US--but judging by UK prices which are on the web (at about 1000 lbs)--it will be somewhere North of $1500. Occasionally used onces show up.
Toyo also makes a similar stove.
The install is fairly simple--cuting the area for the burners, the hole in the hull, ventillation slot and mounting the fuel tank, and hooking up the wire directly to the battery. Probably a day's work.
Rob & Karen
City/Region: Franklin
State or Province: TN
Vessel Name: Life of Riley
Photos: Life of Riley
PostPosted: Thu Mar 06, 2008 9:14 pm    Post subject: Reply with quote
As Ron mentioned, you could also keep the existing stove and add a Wallas heater. There are several too choose from. We added the 1300 to our CD22 and are very happy with it.
http://www.scanmarineusa.com/wallas_furnaces.html
Rob
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Thu Mar 06, 2008 9:47 pm    Post subject: Re: Wallas Stove - Purchase One? Reply with quote
Thanks!!
I did just that last fall (picts in JMR II album) $2340.00
mpmccoy
City/Region: La Habra Heights
Vessel Name: Sea Queen
Photos: Sea Queen
PostPosted: Fri Mar 07, 2008 1:27 am    Post subject: Reply with quote
Bought mine from Scan Marine. Great support...easy to install. See all the pictures of the install in SeaQueen Album
Other's have documented their installs also.
I wouldn't be without the Wallas.
Sea-Ya
C-Hawk
Vessel Name: C-Hawk
Photos: C-Hawk
PostPosted: Fri Mar 07, 2008 9:33 am    Post subject: Reply with quote
Fishtales had the Origo stove (an ok stove for cooking), but I had a Wallas installed.
So - to answer your question--- Yes you can add a Wallas after market.
If you have the Origo, you will need to retrofit for the Wallas. The Origo is larger than the Wallas and you will need to fill in around the counter.
2008- CD22- "C-Hawk" Sold
KJ6VVB
A Brat I am, At sea I be
Page generation time: 0.0323s (PHP: 62% - SQL: 38%) - SQL queries: 25 - GZIP disabled - Debug on
