Two questions
ken 120
City/Region: Sea Isle City,
State or Province: NJ
PostPosted: Sat Mar 08, 2008 12:48 pm    Post subject: Two questions Reply with quote
Hello All:
Trying to find the discussions on "seperating rub rail" that was discussed about six months ago - can't seem to find it now - anyone remember key words that I can use in a search ? Rub rail" did not get me there.
Blisters - I have a used 2001 22 foot C-dory. I keep it in the water from May to November. I am thinking of stripping the bottom paint and applying a barrier coat - looks like a big job - Blisters a 'heard of" problem on C-Dory's?
Thanks
Ken
SEA3PO
City/Region: Chester
Vessel Name: SEA3PO
Photos: SEA3PO
PostPosted: Sat Mar 08, 2008 1:00 pm    Post subject: Reply with quote
When I redid the bottom on my ole tug, if I remember correctly the barrier coat was just a layer of resin....then the bottom paint was applied over the barrier coat.... I would think that the gel coat on a C-Dory would be the barrier coat and the bottom paint could be applied directly over the gel coat... the resin coat was to seal any spot that was poris in the original finish....
I have never heard of anyone with a blister on a C-Dory .....ever.
Joel
SEA3PO
flrockytop
Photos: C-LOVER
PostPosted: Sat Mar 08, 2008 1:35 pm    Post subject: Reply with quote
Joel
SEA3PO
Wasn't there a case about a year ago where someone had a case very small "blisters" in the green colored gel coat. It seems that the answer from factory(Jeff at the time), was that it was cosmetic, but I think they did fix it. There was a big discussion about it, but I can't find it now, so I maybe just dreaming.
2007 22 Cruiser
Track Me HERE
NA4RR
Roger Rockwell
Pensacola, Fl
Fairbro
City/Region: Prescott
Vessel Name: Minnie Swann
Photos: Minnie Swann
PostPosted: Sat Mar 08, 2008 2:03 pm    Post subject: Reply with quote
The long discusion of blisters is under the topic title: Should have gotten a Bayliner. Hard to type that. My "pimple" blisters have not changed so I am not concerned although I did quit pressure washing.
It's something in the water!
PostPosted: Sat Mar 08, 2008 6:01 pm    Post subject: Reply with quote
Here are some threads on blisters, bottom paint, and rub rails:
Bottom Paint, Blisters
Should Have Bought a Bayliner
2003 c-dory 22' blister problem
Bottom Paint Dilemma
Rub Rails
rubrail coming loose
rubrail
Rub Rail
Rub rails on a C-Dory 16
Rubrail rainwater leaks in 22' C-Dory
CD25 H2O leakage via rub rail screw holes.
Rub Rails and End Caps
PostPosted: Sat Mar 08, 2008 6:09 pm    Post subject: Reply with quote
There have been several boats with "Blister" reports. Some appear to be more defect in the gel coat than true osmotic blisters.
Either way, as long as there are no blisters on the bottom, then stripping the bottom paint is not an easy job. There are several ways to remove the bottom paint. Chemical strippers, soda blasting (needs a real expert, because even soda blasting can damage the gel coat--sand blasting is a "no no".) and sanding. After the paint is off (there can be residuals in scratches), the bottom needs to be sanded, dewaxed and then 10 to 20 mil of epoxy built up--usually 4 to 5 coats will suffice. The epoxy is much less permiable to water than gel coat. Modern C Dories are susposed to have a layer of vinlyester resin under the gel coat. But the factory still suggests that epoxy be applied on boats which are kept in the water.
Page generation time: 0.0313s (PHP: 64% - SQL: 36%) - SQL queries: 19 - GZIP disabled - Debug on
