Rub Rails and End Caps
cbadmin
PostPosted: Sun Nov 02, 2003 7:29 pm    Post subject: Rub Rails and End Caps Reply with quote
From: Makushin (Original Message) Sent: 10/29/2003 4:10 PM
I recently bought a '95 CD 16' Angler. The rubrail at the starboard bow was slightly damaged. Specifically about 8 inches of the rail was bent, shearing the rivet that hold the end cap and end of rail in place.
The original endcap was aluminum and I believe held in place by a rivet.
I called the CD factory and they provided me with the end caps that they are currently using....plastic. I was told that they should still work.
Can anyone tell me how the newer endcaps are fastened...it looks to me like they are not designed for a rivet. I would also appreciate any advise for a sound method of bending and reattaching the rub rail itself especially since
PostPosted: Mon Jul 18, 2005 10:15 am    Post subject: Rub Rail Rubber Insert Replacement Reply with quote
Does anyone have a source for the rub rail rubber insert for an older CD22 (1994)? I found some the right shape, etc at WMarine but it's a little too small overall.
PostPosted: Mon Jul 18, 2005 7:07 pm    Post subject: Reply with quote
Charlie and Sally-
I waited to see if anyone was going to come up with a direct solution to this question. With none in sight yet, I looked in the WM on line catalogue to see what you were looking at. I then went to the TACO (manufacturer's) site and found the following:
(Go to page 6 of the file)
http://www.tacomarine.com/diypages/aluminumrr.asp
The Aluminum rail # A12-0305BLY12D looks like a match for the one on the boat, minus two fingers of the extrusion which could have been cut off to mount it on a flat surface, and the insert #V12-0303BKA50 looks to be a very good match for the one on the boat.
Perhaps you could ask their technical support people if they know if the products above are a match for the earlier C-Dorys and / or if they think they will fit, and if they could send you a short sample of the insert to try out.
Let us know how things work out! Good Luck! Joe.
Norm S
City/Region: Tacoma Wa
C-Dory Model: 18 Angler
Vessel Name: The Divine Miss C
Photos: The Divine Miss C
PostPosted: Mon Jul 18, 2005 7:38 pm    Post subject: Reply with quote
I recently picked up new insert from the factory. The rubrail on the new boats appears to be the same as on my 84. I have not installed it yet but did try a small piece to make sure it would fit. Appeared to me to be the same as orig.
Norm
If You're not living on the edge you're taking up too much space!
Page generation time: 0.0314s (PHP: 62% - SQL: 38%) - SQL queries: 17 - GZIP disabled - Debug on
