Hour meter
dotnmarty
City/Region: Sammamish
Vessel Name: LIZZIE II
Photos: Lizzie
PostPosted: Sun Feb 17, 2008 7:22 pm    Post subject: Hour meter Reply with quote
When I had my Honda main engine serviced I also had an hour meter installed. When I first turned on the engine after the service it read 146.3 hours. Was this information retrieved electronically from the engine? Thanks
MartyP
dogon dory
Vessel Name: DogOnDory
PostPosted: Sun Feb 17, 2008 7:24 pm    Post subject: Reply with quote
Alyssa Jean
Vessel Name: Alyssa Jean
PostPosted: Sun Feb 17, 2008 8:25 pm    Post subject: Reply with quote
Is the hours meter a digital or analog? If it is an analog they cvan be zero'd by shorting across two of the terminals in the back. The bad news is that I can't remember which two.
David and Kate
Alyssa Jean 16 Angler
K7KJR C-Brats #51
PostPosted: Sun Feb 17, 2008 10:53 pm    Post subject: Reply with quote
My honda and Suzuki are "electrical/mechanical"--using a clock on 12 volts, and when I switched them out, they read zero...I ran them on a battery bank or 12 volt power supply until they read what was on the engine by history from the failed hour meter.
PostPosted: Sun Feb 17, 2008 11:13 pm    Post subject: Reply with quote
My Suzis are that way too. 2001 engines put on a 2006 boat. The meters read the time since installed in 2006, the tachs which are linked to the engines read the real time on the engines with the tach readings, as described by the engine manuals.
tom&shan
Photos: Dakota
PostPosted: Sun Feb 17, 2008 11:56 pm    Post subject: Re: Hour meter Reply with quote
You should of paid for a new meter Marty, sounds like you got a "used" one Wink .
On a serious note - is that close to what you thought the engine had on it?
Tom
dotnmarty
Photos: Lizzie
PostPosted: Mon Feb 18, 2008 8:45 am    Post subject: Reply with quote
It's a Honda digital meter. The number showing is about 30% less than I had estimated were on the engine. I'm going with Dan's assessment on this one. Thanks
Page generation time: 0.0342s (PHP: 62% - SQL: 38%) - SQL queries: 20 - GZIP disabled - Debug on
