dotnmarty
Joined: 03 Nov 2003 Posts: 4209 City/Region: Sammamish
Vessel Name: LIZZIE II
Photos: Lizzie
Posted: Sun Feb 17, 2008 7:22 pm Post subject: Hour meter |
When I had my Honda main engine serviced I also had an hour meter installed. When I first turned on the engine after the service it read 146.3 hours. Was this information retrieved electronically from the engine? Thanks _________________ MartyP
"...we're all in the same boat..." |
dogon dory
Vessel Name: DogOnDory
Posted: Sun Feb 17, 2008 7:24 pm Post subject: |
Alyssa Jean
Joined: 02 Nov 2003 Posts: 2376 City/Region: Guemes Is.(Anacortes)
Vessel Name: Alyssa Jean
Posted: Sun Feb 17, 2008 8:25 pm Post subject: |
Is the hours meter a digital or analog? If it is an analog they cvan be zero'd by shorting across two of the terminals in the back. The bad news is that I can't remember which two. _________________ David and Kate
Alyssa Jean 16 Angler
K7KJR C-Brats #51 |
Joined: 02 Nov 2003 Posts: 21468 City/Region: Pensacola
Posted: Sun Feb 17, 2008 10:53 pm Post subject: |
My honda and Suzuki are "electrical/mechanical"--using a clock on 12 volts, and when I switched them out, they read zero...I ran them on a battery bank or 12 volt power supply until they read what was on the engine by history from the failed hour meter. _________________ Bob Austin
Posted: Sun Feb 17, 2008 11:13 pm Post subject: |
My Suzis are that way too. 2001 engines put on a 2006 boat. The meters read the time since installed in 2006, the tachs which are linked to the engines read the real time on the engines with the tach readings, as described by the engine manuals.
K4KBA |
tom&shan
Photos: Dakota
Posted: Sun Feb 17, 2008 11:56 pm Post subject: Re: Hour meter |
dotnmarty wrote: | When I had my Honda main engine serviced I also had an hour meter installed. When I first turned on the engine after the service it read 146.3 hours. Was this information retrieved electronically from the engine? Thanks |
You should of paid for a new meter Marty, sounds like you got a "used" one .
On a serious note - is that close to what you thought the engine had on it?
Tom |
dotnmarty
Photos: Lizzie
Posted: Mon Feb 18, 2008 8:45 am Post subject: |
It's a Honda digital meter. The number showing is about 30% less than I had estimated were on the engine. I'm going with Dan's assessment on this one. Thanks |
