dotnmarty
Vessel Name: LIZZIE II
Photos: Lizzie
Posted: Fri Jul 13, 2007 6:41 pm Post subject: Swim platform |
I want to put a swim platform on so that I can easily flush out the motor while in the slip and change the prop etc. The factory one is listed for about $450! Has anyone had good results with an alternative cheaper one? Thanks _________________ MartyP
Joined: 02 Nov 2003 Posts: 20860 City/Region: Pensacola
Posted: Fri Jul 13, 2007 7:00 pm Post subject: |
I put the "outboard" model of AFI on the CD 25. Has a nice ladder, works fine. Perhpas a bit more diffucult to bolt in place. I have used this on several boats in the past. The issue may be if there is enough space on the transom for the platform and the motor to turn to each side.
Cost was about $120 wholesale price. _________________ Bob Austin
dotnmarty
Photos: Lizzie
Posted: Fri Jul 13, 2007 7:18 pm Post subject: |
Did you use the teak or the poly? Thanks for your response. |
