Swim platform
dotnmarty
City/Region: Sammamish
Vessel Name: LIZZIE II
Photos: Lizzie
PostPosted: Fri Jul 13, 2007 6:41 pm    Post subject: Swim platform Reply with quote
I want to put a swim platform on so that I can easily flush out the motor while in the slip and change the prop etc. The factory one is listed for about $450! Has anyone had good results with an alternative cheaper one? Thanks
MartyP
PostPosted: Fri Jul 13, 2007 7:00 pm    Post subject: Reply with quote
I put the "outboard" model of AFI on the CD 25. Has a nice ladder, works fine. Perhpas a bit more diffucult to bolt in place. I have used this on several boats in the past. The issue may be if there is enough space on the transom for the platform and the motor to turn to each side.
Cost was about $120 wholesale price.
dotnmarty
Photos: Lizzie
PostPosted: Fri Jul 13, 2007 7:18 pm    Post subject: Reply with quote
Did you use the teak or the poly? Thanks for your response.
Page generation time: 0.0196s (PHP: 57% - SQL: 43%) - SQL queries: 20 - GZIP disabled - Debug on
