gas filter
westward
C-Dory Year: 1985
Vessel Name: TBD
Photos: Steady Eddy
PostPosted: Fri Feb 09, 2007 10:05 am    Post subject: gas filter Reply with quote
Anyone know the product # for the spin-on fuel filter the factory installs in the splash well of the 22? I need to replace mine this weekend, the boat is up in the islands, and I'm here in Seattle. Thanks, Mike.
CatyMae n Steve
City/Region: Jefferson, OR
Vessel Name: CatyMae
Photos: CatyMae
PostPosted: Fri Feb 09, 2007 3:12 pm    Post subject: Reply with quote
May not be factory install? I'd guess maybe whoever rigged the motors would have chosen what type. Just a guess.
Caty
Almas Only
City/Region: Richmond
Vessel Name: Alma's Only
Photos: Alma's Only
PostPosted: Sun Sep 16, 2007 11:20 am    Post subject: Reply with quote
I recently replaced the in line fuel filter (the plastic one under the motor cover) on our Honda 90 with a non-Honda (i.e., readily available and reasonably priced) part. It was Sierra PN 18-7786, West Marine SKU 3735909. The Sierra label says: "REPLACES HONDA 16900-SA5-004 BF35/45, BF40/50, BF75& BF90".
2003 CD22 Cruiser with Honda 90
PostPosted: Sun Sep 16, 2007 12:08 pm    Post subject: Reply with quote
I've just replaced both engine fuel filters, the plastic ones under the cowl with Honda parts. They were reasonable too, only 9 bucks or so each.
My bigger filters are in the stbd lazarette and are Sierra 18-7844. They are all metal, don't have the clear bowl beneath them. I've cleaned them many times by just unscrewing them and dumping into a pail for disposal. Just did both of them.
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Sun Sep 16, 2007 12:12 pm    Post subject: Re: gas filter Reply with quote
Does it have a clear bowl on the bottom as in Racor, or is it all steel like a automotive spin on oil filter? Mr. Green Beer
snal
City/Region: Asheville
C-Dory Year: 1994
Vessel Name: Thelma Lou
Photos: Thelma Lou
PostPosted: Sun Sep 16, 2007 12:37 pm    Post subject: Reply with quote
Mine are located there as well. Do you also have a battery in that lazarette? Mine does, and I'm a bit concerned about changing them, and possibly spilling a bit of fuel in an area where a spark could occur. I suppose I could remove the battery before changing the filters.
Snal~
(Larry and Jo)
1994 C Dory 22 Angler (sold 2012)
Currently looking for a steal of a deal on a 25' "Thelma Lou II"
Chester
City/Region: home
Photos: Chester
PostPosted: Sun Sep 16, 2007 12:44 pm    Post subject: Reply with quote
Go to the Honda website, choose Honda Marine, go to assesories and select fuel systems. That should help you choose the correct part.
PostPosted: Sun Sep 16, 2007 12:57 pm    Post subject: Reply with quote
Those spin on filters are NOT Honda parts. They were put on when the boat was rigged.
Yes, snal, I have a battery in there along with the 1-2-ALL switch. It's a group 27 battery too, larger than the normal one. I've changed/cleaned them many times, even spilled a little with no mishaps. If you're careful, you can do it without spilling but it's tricky. Just make sure to shut off the switch before you start so there are no sparks. Shocked
One of my projects this winter was going to be to move them out to the splashwell but now that I'm selling the boat, I'll let the new owner decide if he wants to do that or not.
snal
C-Dory Year: 1994
Photos: Thelma Lou
PostPosted: Sun Sep 16, 2007 1:09 pm    Post subject: Reply with quote
Sounds just like my setup. My battery switch is in there also. I kinda like having them there VS the splashwell. The battery in that lazarette is inserted, then turned crosswise and strapped down...makes getting to the filters fairly easy.
Page generation time: 0.0628s (PHP: 65% - SQL: 35%) - SQL queries: 22 - GZIP disabled - Debug on
