Gene Morris
Joined: 28 Sep 2006 Posts: 424 City/Region: Eureka CA
Vessel Name: Reef Madness
Photos: Reefmadness
Posted: Sun Jan 14, 2007 2:08 pm Post subject: Hydraulic trim tabs for TomCat |
Has anyone seen Hydraulic trim tabs available for the TomCat. I had those on the previous boat and would be interested in the usefulness of them on a catamaran.
Gene _________________ tight lines |
Joined: 02 Nov 2003 Posts: 21607 City/Region: Pensacola
Posted: Sun Jan 14, 2007 3:38 pm Post subject: |
Gene, I don't see how they could be fitted. First they will interfere with the flow of water to the outboard props. Secondly, they will not be able to fitted flush to the bottom of the boat (because of the hull geometry. Finally there is not enough room for the ram unless you modify the Armstrong bracket.
I think we are "stuck" with cavitation plate foils--like the Permitrims or Dolfins.
There is another possibility--that is hyrafoils--much different than trim tabs, but they have been used on some cats. The hulls and wing deck would probably have to be re-inforced to allow use of these. Most likely one could not trailer the boat easily with foils in place--so it is not an easy solution either.
Bob Austin _________________ Bob Austin
drjohn71a
State or Province: KS
Vessel Name: Tom-a-Hawk
Photos: Tom-a-Hawk
Posted: Mon Jan 15, 2007 12:43 pm Post subject: |
Gene,
I had the same thought for a long time, but could not see any way to get a set large enough set into that busy and small area between the hull and the props. I went with the Permatrims and am very pleased with the performance. I think it's better to not penetrate the hull with fasteners anyway.
Since then, I have seen a cast aluminum version of engine trim tab that curves down on the edges. I think that model could be even more advantageous in all that 'loose water' around the props.
John |
