Hydraulic trim tabs for TomCat
Gene Morris
City/Region: Eureka CA
Vessel Name: Reef Madness
Photos: Reefmadness
PostPosted: Sun Jan 14, 2007 2:08 pm    Post subject: Hydraulic trim tabs for TomCat Reply with quote
Has anyone seen Hydraulic trim tabs available for the TomCat. I had those on the previous boat and would be interested in the usefulness of them on a catamaran.
Gene
tight lines
PostPosted: Sun Jan 14, 2007 3:38 pm    Post subject: Reply with quote
Gene, I don't see how they could be fitted. First they will interfere with the flow of water to the outboard props. Secondly, they will not be able to fitted flush to the bottom of the boat (because of the hull geometry. Finally there is not enough room for the ram unless you modify the Armstrong bracket.
I think we are "stuck" with cavitation plate foils--like the Permitrims or Dolfins.
There is another possibility--that is hyrafoils--much different than trim tabs, but they have been used on some cats. The hulls and wing deck would probably have to be re-inforced to allow use of these. Most likely one could not trailer the boat easily with foils in place--so it is not an easy solution either.
drjohn71a
City/Region: Wichita
State or Province: KS
Vessel Name: Tom-a-Hawk
Photos: Tom-a-Hawk
PostPosted: Mon Jan 15, 2007 12:43 pm    Post subject: Reply with quote
Gene,
I had the same thought for a long time, but could not see any way to get a set large enough set into that busy and small area between the hull and the props. I went with the Permatrims and am very pleased with the performance. I think it's better to not penetrate the hull with fasteners anyway.
Since then, I have seen a cast aluminum version of engine trim tab that curves down on the edges. I think that model could be even more advantageous in all that 'loose water' around the props.
Page generation time: 0.0186s (PHP: 63% - SQL: 37%) - SQL queries: 20 - GZIP disabled - Debug on
