Motor Connector Rods
Jazzmanic
Photos: C-Dancer
PostPosted: Thu Jan 04, 2007 4:19 pm    Post subject: Motor Connector Rods Reply with quote
I've been thinking about purchasing a connector rod tieing the Kicker to the Main. I've searched different threads but need some definitive answers.
1. EZ Steer connector rods look good but are they worth $200?
2. Do the Cabelas connector rods do the job?
3. Can the Cabelas connector rods still be attached if the Main is tilted out of the water? Or do you need to disconnect them with the quick disconnects?
4. Does anyone know what connector rod the factory was using?
Peter
Adeline
City/Region: Vancouver
Vessel Name: Adeline
Photos: Adeline
PostPosted: Thu Jan 04, 2007 7:29 pm    Post subject: Reply with quote
The steering rod in the photo I believe is called Goldeneye Panther Auxiliary Motor Steering Kit
http://www.edbydesign.com/books/B0009TPV1K.html It is similar to the original on Adeline(1989). It can be seen here http://www.c-brats.com/modules.php?set_albumName=album61&op=modload&name=gallery&file=index&include=view_album.php If you decide you want an EZ steer I have an "as new" one I'll let go for a hundred.
Pete
416rigby
Vessel Name: Foggy Dew
Photos: Foggy Dew
PostPosted: Thu Jan 04, 2007 8:13 pm    Post subject: Reply with quote
The Cabela's one looks just like the one pictured above. We had one on our last boat and it worked great. I think the stainless version form Cabela's is 50 bucks. Ours worked when main was in or out of the water.
Rick
Jazzmanic
Photos: C-Dancer
PostPosted: Fri Jan 05, 2007 12:37 am    Post subject: Reply with quote
Thanks fpr the offer, Pete. It's mighty tempting but I think I'm going to try the Cabelas connecting rod first. I think it's very similar to the one in your picture.
And thanks Rick. I'm also thinking about adding the TrollMaster Pro II found at Cabelas as well. It sounds like it works for you.
Peter
Page generation time: 0.0248s (PHP: 59% - SQL: 41%) - SQL queries: 17 - GZIP disabled - Debug on
