1987 22 Cruiser Lazarette cover replacement
Devilfish55
Vessel Name: Devilfish
Photos: Devilfish
PostPosted: Thu Jul 07, 2022 5:29 pm    Post subject: 1987 22 Cruiser Lazarette cover replacement Reply with quote
Any advice on what to replace my lazarette covers with? Mine leak and need attention.
PostPosted: Thu Jul 07, 2022 9:44 pm    Post subject: Reply with quote
That is probably going to be a difficult chore--since your hatch is not similar to the vast majority of hatches which have been replaced.
hopefully you will find a candidate on the Imtra web site.
You may even have to build a new fiberglass fill around an edge or two to get a size which will work.
PostPosted: Thu Jul 07, 2022 11:38 pm    Post subject: Reply with quote
Bob is right. You are going to want anything that gets above that depressed opening, so water sheds off the top of the laz and not drains down into it.
digger
City/Region: Spokane
Vessel Name: C-Sik
Photos: Snoopy-C
PostPosted: Thu Jul 07, 2022 11:45 pm    Post subject: Reply with quote
Check out pages 3&4 on Snoopy-C photo album. Had same exact covers, and this shows the steps I took to complete lazarette replacement. Came out well. http://www.c-brats.com/modules.php?set_albumName=Snoopy-C&id=IMG_0038&op=modload&name=gallery&file=index&include=view_photo.php
PostPosted: Fri Jul 08, 2022 10:32 am    Post subject: Reply with quote
Very nice job! It appears as if you were able to use the Imtra hatch:
digger
Vessel Name: C-Sik
Photos: Snoopy-C
PostPosted: Fri Jul 08, 2022 10:43 am    Post subject: Reply with quote
Thanks. It came out well, and the hatch has a seal on the underside of the frame, so it was unnecessary to put a raised lip on the mounting surface. The original lazarette seemed to be an afterthought of that year design, and was poorly thoughtout.
PostPosted: Fri Jul 08, 2022 11:12 am    Post subject: Reply with quote
I see this was done on "C Major". What year was she built? My 1993. C Dory 22 had the leaking stock hatches.
Devilfish55
Photos: Devilfish
PostPosted: Fri Jul 08, 2022 12:48 pm    Post subject: Reply with quote
Wow, this is what I need to do! What size hatch did you use?
digger
Vessel Name: C-Sik
Photos: Snoopy-C
PostPosted: Fri Jul 08, 2022 3:58 pm    Post subject: Reply with quote
C-Miner (renamed) is a 1988 cruiser. I do not remember the hatch size - it was a long time ago. I just measured the existing opening and got the hatches that had “close” dimensions. Had to cut an in insert and glass it in anyway, so it can be sized accordingly. The duraglass was purchased at an autobody / paint supply store. It has glass filaments in fiberglass filler to provide strength. Once completed, it never exhibited cracking, etc while I owned it. My current 1993 Angler has raised ridge around the opening and the cover, although not gasketed, has a dipping out perimeter that stops water intrusion.
Page generation time: 0.0337s (PHP: 65% - SQL: 35%) - SQL queries: 22 - GZIP disabled - Debug on
