Corrosion on my prop
Mike B
City/Region: Staten Island
State or Province: NY
Vessel Name: Remembrance
Photos: Remembrance
PostPosted: Thu Nov 18, 2021 1:29 pm    Post subject: Corrosion on my prop Reply with quote
I'm winterizing my 2017 Yamaha 115 today and found that my propeller has a considerable amount of corrosion on the back that faces the engine. its an aluminum prop. Is there an anode I should be looking for. Everything else looks great, just the back of the prop that sits on that bearing. Thanks
PostPosted: Thu Nov 18, 2021 1:40 pm    Post subject: Reply with quote
A photo would be very helpful.. Are you leaving the prop in the water when the boat Is left in the water? What type of water are you boating in. Is a 110 volt AC system plugged in when the boat is in the water?
It could be Cavitation (Basically boiling water in a low pressure area-as opposed to "Ventilation" where air is reaching the blades of the prop because of improper flow or trim.
It could break electrolysis/or Corrosion.
Mike B
Photos: Remembrance
PostPosted: Thu Nov 18, 2021 6:13 pm    Post subject: Reply with quote
I might have been something I did at the beginning of last season, I may not have tightened it down enough. I realize now it came off too easy. Time to get a torque wrench. I didn't take a picture, Its always raised out of the water when at the dock and a lot of time when its not running and there is no ac within 75 feet. Thanks for the reply.
PostPosted: Thu Nov 18, 2021 8:49 pm    Post subject: Reply with quote
It is possible that if the distance from the hub perhaps with an improper thrust washer, could cause more turbulence and the lower pressure?
When you get a chance take a photo.
Page generation time: 0.0421s (PHP: 38% - SQL: 62%) - SQL queries: 17 - GZIP disabled - Debug on
