22" Angler decking
firemike115
City/Region: Northern California
PostPosted: Thu Jan 06, 2022 7:35 pm    Post subject: 22" Angler decking Reply with quote
I'm looking at a 2008 22' Angler. Has painted wood decking. Is this normal for this boat> Is there a fiberglass deck under it?
PostPosted: Thu Jan 06, 2022 11:06 pm    Post subject: Reply with quote
I don't know about the angler, but the cruiser of that vintage had a raised fiberglass floor over the cockpit. A year or so older had a two part floor which could be removed. Prior to 2005/6 the boats "floor" was generally the inner hull.
A built up floor would would not be a detriment. I would not want a floor screwed to the inner aspect of the hull. It could be laid in a sealant or adhesive and be fine.
firemike115
PostPosted: Fri Jan 07, 2022 4:57 pm    Post subject: Decking Reply with quote
Thanks, Yes, my inexperience with these boats is showing. The decking is just an attempt to place a flat surface over the hull/deck. It's wood and it looks kinda rough.
Page generation time: 0.0425s (PHP: 31% - SQL: 69%) - SQL queries: 17 - GZIP disabled - Debug on
