firemike115
Joined: 01 Jan 2022 Posts: 3 City/Region: Northern California
Posted: Thu Jan 06, 2022 7:35 pm Post subject: 22" Angler decking |
I'm looking at a 2008 22' Angler. Has painted wood decking. Is this normal for this boat> Is there a fiberglass deck under it? |
Joined: 02 Nov 2003 Posts: 21529 City/Region: Pensacola
Posted: Thu Jan 06, 2022 11:06 pm Post subject: |
I don't know about the angler, but the cruiser of that vintage had a raised fiberglass floor over the cockpit. A year or so older had a two part floor which could be removed. Prior to 2005/6 the boats "floor" was generally the inner hull.
A built up floor would would not be a detriment. I would not want a floor screwed to the inner aspect of the hull. It could be laid in a sealant or adhesive and be fine. _________________ Bob Austin
firemike115
Posted: Fri Jan 07, 2022 4:57 pm Post subject: Decking |
Thanks, Yes, my inexperience with these boats is showing. The decking is just an attempt to place a flat surface over the hull/deck. It's wood and it looks kinda rough. |
