garyf
C-Dory Year: 1991
Vessel Name: C-Story
Photos: C-Story
Posted: Fri Apr 30, 2021 7:20 am Post subject: Sea Dog Fuse Panel |
I feel a little weird asking this question, but how the heck do you get the fuses out of this thing if you need to replace one or whatever?
I've tried pushing, pulling, looking behind the panel, etc. I don't want to force or break anything so I figured I'd ask.
 _________________ Gary Frerking
C-Story
'91 22 ft Cruiser
'08 Yamaha 90
KC3PO |
tsturm
Joined: 01 Nov 2003 Posts: 1170 City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
Posted: Fri Apr 30, 2021 8:53 am Post subject: Re: Sea Dog Fuse Panel |
garyf wrote: | I feel a little weird asking this question, but how the heck do you get the fuses out of this thing if you need to replace one or whatever?
There are 2 little bumps on either side of the square FUSE thing. Use a knife blade or jewelers screw driver to GENTLY pry the RED Fuse cover out. You will probably break the little tabs, I would replace the whole thing  |
Marco Flamingo
Vessel Name: Limpet
Photos: Limpet
Posted: Fri Apr 30, 2021 10:44 am Post subject: |
Mine have a tiny slot on the black plastic at the top of the red plastic (maybe also on the bottom, I've never looked). Pushing in this slot with the right size tool (jeweler's screwdriver works) makes the red plastic pop out with the fuse.
These panels are routinely over fused. I think SeaDog lists them as 10A max. Mine had both 15 and 20A fuses, apparently without proplems (yet). I had to pull them all out to inspect so had plenty of practice popping out the fuses. I made new labels that included the fuse size (i.e., "VHF 3A") to make replacement easier. When the fuse blows, the lighted switch goes out, making it easy to see which one is the problem, but still a pain to pop that little fuse holder open.
Mark |
garyf
C-Dory Year: 1991
Photos: C-Story
Posted: Fri Apr 30, 2021 2:04 pm Post subject: |
Thanks both of you... I'll take a closer look next time I'm out there. It's 30 years old, so I agree with the possibility of something plastic breaking. I have looked at possible replacements from Blue Sea and elsewhere, and may end up doing that. Of course, it has to be a pretty small panel to fit in the same spot.
Even the newer Sea Dog units seem to be better with circuit breakers instead of fuses. |
Gary5410
C-Dory Year: 1991
Photos: Gary5410
Posted: Wed May 05, 2021 9:32 pm Post subject: Re: Sea Dog Fuse Panel |
On the left side of the fuse cover is a small hole .... stick something pointy in there a it will pop out.
Edit .....Oops.... too late - you got it! _________________ 1991 C-Dory 21’ Pro-Angler |
Gary5410
C-Dory Year: 1991
Photos: Gary5410
Posted: Wed May 05, 2021 9:34 pm Post subject: Re: Sea Dog Fuse Panel |
On the left side of the fuse cover is a small hole .... stick something pointy in there a it will pop out. |
Joined: 07 Nov 2003 Posts: 7935 City/Region: marysville
Posted: Thu May 06, 2021 1:36 am Post subject: |
I have these and yes a knife tip works well. HOLD YOUR HAND OVER THE RED PART OR GET READY TO CHASE DOWN THE SPRING. Ask me how I know.... _________________ Thomas J Elliott
garyf
C-Dory Year: 1991
Photos: C-Story
Posted: Thu May 06, 2021 2:22 am Post subject: |
Got it figured out, thanks everyone. I'm good for now. I wouldn't mind finding a more modern replacement with LED lights and so on, but it's not going to be high on my list. Overall, this thing seems to be in pretty good shape. |
dotnmarty
Joined: 03 Nov 2003 Posts: 4209 City/Region: Sammamish
Vessel Name: LIZZIE II
Photos: Lizzie
Posted: Thu May 06, 2021 1:25 pm Post subject: Re: Sea Dog Fuse Panel |
By the way, if you lose the mast light cap, the screw cover from a small propane canister fits perfectly. _________________ MartyP
