Karl Konecny
Vessel Name: Nowhere Fast
Photos: Nowhere Fast
Posted: Tue Jun 16, 2020 11:09 am Post subject: Cabin interior and cabin deck paint |
Much of the original paint has flaked off the cabin deck of my 2008 22' cruiser. It has also flaked off the wall in few spots. What is the recommended paint to replace it? The original is flat and appears to have been put on fairly thick. _________________ "Believe me my young friend, there is nothing-absolutely nothing-half so much worth doing as simply messing around in boats."
Rat to Mole, Wind in the Willows |
Posted: Tue Jun 16, 2020 11:15 am Post subject: |
Photos would help: Is this the floor (inside of the hull)? Or the actual deck on the outside. Is the area the cabin walls, below the hull line or inside the upper part of the cabin? Ask the moderator for an album.
What colors? Some boats have rolled on gel coat on the floor, some one of the bilge gray paints, others a sprayed on off white paint on the walls, with specs. _________________ Bob Austin
Ferg
Joined: 18 Jun 2015 Posts: 187 City/Region: Oak Island
Vessel Name: Here & Now
Photos: Here & Now
Posted: Tue Jun 16, 2020 1:21 pm Post subject: |
I had the same problem on the cabin walls, and had Spectrum Paint custom match and mix. It’s been on for three years, and still looks great
It’s:
PPG-Break-Through!
Ultra-Durable Water-Borne Acrylic
Interior;Exterior
Satin
White&Pastel Base (V50-410)
Color mix:
C-12.5, L-1, M-1.5, W-24 |
Karl Konecny
Posted: Wed Jun 17, 2020 12:48 pm Post subject: |
Thanks Bob and Ferg,
I've been meaning to start an album, so I'd better get to it. I'm doing lots of projects on the boat that I should post. Great work for these times. The paint is lifting off the inside of the hull which is the floor of the cabin, kind of an off-white / pale tan color. The cabin walls are a flat off white with tan specks. The paint chipped off the section between the fore and aft windows on the starboard side. |
