Cabin interior and cabin deck paint
Karl Konecny
City/Region: Glide
Vessel Name: Nowhere Fast
Photos: Nowhere Fast
PostPosted: Tue Jun 16, 2020 11:09 am    Post subject: Cabin interior and cabin deck paint Reply with quote
Much of the original paint has flaked off the cabin deck of my 2008 22' cruiser. It has also flaked off the wall in few spots. What is the recommended paint to replace it? The original is flat and appears to have been put on fairly thick.
PostPosted: Tue Jun 16, 2020 11:15 am    Post subject: Reply with quote
Photos would help: Is this the floor (inside of the hull)? Or the actual deck on the outside. Is the area the cabin walls, below the hull line or inside the upper part of the cabin? Ask the moderator for an album.
What colors? Some boats have rolled on gel coat on the floor, some one of the bilge gray paints, others a sprayed on off white paint on the walls, with specs.
Ferg
City/Region: Oak Island
Vessel Name: Here & Now
Photos: Here & Now
PostPosted: Tue Jun 16, 2020 1:21 pm    Post subject: Reply with quote
I had the same problem on the cabin walls, and had Spectrum Paint custom match and mix. It’s been on for three years, and still looks great
It’s:
PPG-Break-Through!
Ultra-Durable Water-Borne Acrylic
Interior;Exterior
Satin
White&Pastel Base (V50-410)
Color mix:
C-12.5, L-1, M-1.5, W-24
Karl Konecny
City/Region: Glide
PostPosted: Wed Jun 17, 2020 12:48 pm    Post subject: Reply with quote
Thanks Bob and Ferg,
I've been meaning to start an album, so I'd better get to it. I'm doing lots of projects on the boat that I should post. Great work for these times. The paint is lifting off the inside of the hull which is the floor of the cabin, kind of an off-white / pale tan color. The cabin walls are a flat off white with tan specks. The paint chipped off the section between the fore and aft windows on the starboard side.
Page generation time: 0.0262s (PHP: 58% - SQL: 42%) - SQL queries: 17 - GZIP disabled - Debug on
