Suzuki vs E-tec
curioustraveler
City/Region: Annapolis
State or Province: MD
Photos: Curioustraveler
PostPosted: Sun Jan 19, 2020 6:50 pm    Post subject: Suzuki vs E-tec Reply with quote
Hello C-Brats.
Assuming all else is equal, boats are in the same condition (19), similar maintenance history, and I have a dealer nearby that services both, what would you go with?
2006 Suzuki 4 stroke 90 or 2008 E-tec? The Evinrude is several thousand more but it's a couple years newer boat and motor - also has a permatrim.
This is for recreational cruising. Not really concerned with top speed or getting on plane a couple seconds quicker. Of upmost importance is reliability and ease (cost) of maintenance.
Thanks.
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Sun Jan 19, 2020 6:58 pm    Post subject: Re: Suzuki vs E-tec Reply with quote
curioustraveler wrote:
Hello C-Brats.
Thanks.
The first gen. E-tec's were not very good motors. The new series E-tec are great. I would go with the Suzuki over the 2008 e-tec. Wink
curioustraveler
PostPosted: Sun Jan 19, 2020 7:06 pm    Post subject: Reply with quote
Thanks Tsturm, I know the early e-Tec's had issues. I walked away from a boat that had a 2000 E-tec. Don't know when they started improving though.
Salmon Fisher
City/Region: Arlington
Vessel Name: Kim Christine
Photos: Kim Christine
PostPosted: Sun Jan 19, 2020 7:25 pm    Post subject: Reply with quote
You might want to read this discussion from another C Brat's experience with the year model of Suzuki you are looking at:
http://www.c-brats.com/viewtopic.php?t=24647
For the ETEC, I have heard others not like them as they are noisier and like the other reply posted, the first generation had some problems.
For what it's worth anyway, glad you're being picky.
Patrick and Kim Walker
2004 25 Cruiser-Present
1985 22 Classic -2019 (Sold)
Robert H. Wilkinson
City/Region: Port Ryerse
State or Province: ON
Vessel Name: Romakeme IV
Photos: Romakeme IV
PostPosted: Sun Jan 19, 2020 9:25 pm    Post subject: Reply with quote
For the Suzuki guys/gals in our group this might be of interest - https://www.facebook.com/BridgeYachts/posts/2709475609105509 .
A friend of mine is introducing the new 2020 Suzuki duoprop outboard at the Toronto Boat Show. Unfortunately I only see them in the 300 and 350hp models. In the smaller hp range Suzuki has the ability to reverse one engine with twins.
Regards,
Rob
curioustraveler
PostPosted: Sun Jan 19, 2020 11:06 pm    Post subject: Reply with quote
Salmon Fisher,
I wonder if that's something I could have a surveyor look for? Honestly though, I'm expecting possible problems with any engine. It's one of the reasons I keep coming back to C-Dory's. If/when I have to repower, it'll be much less money than replacing a 150 or 200 on the back of most walk-a-rounds.
jkswor
City/Region: tok
Vessel Name: Missy marie
PostPosted: Mon Jan 20, 2020 10:00 am    Post subject: Reply with quote
I bought a 25 cdory in 2017. Had 2 2007 90 hp etec s on it. Only issue I had was one fuel injector fail. Had all 6 injectors cleaned by fuel injector man in Naples fl. Last month. So shouldn’t have any more issues. So I’ve been told the 07s are good motors if maintained. Have served me well
They are lighter than others and have a lot of power.
There is an etec owners group or forum which is very helpful
Salmon Fisher
PostPosted: Mon Jan 20, 2020 10:49 am    Post subject: Reply with quote
There is a history of Suzuki corrosion failures in the year range. Might want to Google it.
PostPosted: Mon Jan 20, 2020 1:09 pm    Post subject: Reply with quote
The Suzuki corrosion problem is that they used a steel plug in an aluminum casting. That was corrected from 2008 on. Many of the pre 2008 motors had that plug replaced and are Fine. If they have been used extensively in salt water and not well rinsed after each use, the plug and surround may be so corroded that it cannot be replaced. I am aware of some of these areas which have been repaired by a good welder.
I would want to have the engine checked by a good mechanic.
curioustraveler
PostPosted: Mon Jan 20, 2020 4:57 pm    Post subject: Reply with quote
Thanks everyone. I just called the broker. The boat's been maintained by a professional shop so I'll check with them and also have the engine looked over again if I decide to move forward with this one.
Any more thoughts on an E-tec?
DavidM
City/Region: Punta Gorda
PostPosted: Mon Jan 20, 2020 5:15 pm    Post subject: Reply with quote
This is what I know about the Etecs:
The original two stroke alternative to the four strokes was the Fitch motor developed by Evinrude. That was a disaster. Evinrude solved most of the Fitch's problems and came out with the Etecs. These were reasonably successful and competed well with contemporary 4 strokes. They were noisier and burned more fuel than the 4 strokes but being a 2 stroke they were somewhat lighter and had great hole shot torque.
In recent years Evinrude came out with the Gen 2 Etecs, but only for 150+ hp engines. The G2s were a significant improvement and compete with the best 4 strokes on fuel economy. They still are a bit noisier, but by a few dB- not so much and probably not even noticeable. Maintenance requirements are particularly simple- no oil changes for example, just add oil every 200 hours or so.
Unfortunately after years of promises there is no immediate hope of a G2 115 hp engine or less.
So the Etec you are considering is a bit newer than the Suzuki and maybe enough to offset its weaknesses....or not, and then you have the corrosion problems of the Suzuki discussed above..
David
BillE
City/Region: Nashville
State or Province: TN
Vessel Name: TBD
Photos: BillE
PostPosted: Mon Jan 20, 2020 6:40 pm    Post subject: Reply with quote
David, Evinrude has recently done just that, released a G2 3-cylinder at 115, 140, and 150hp. I have no experience with these motors but do a search and you will find lots of online discussion about the new series.
Bill & Sherry C-25 sold 2020, next?
cmetzenberg
City/Region: Santa Barbara
Vessel Name: Kanaloa
Photos: Kanaloa
PostPosted: Mon Jan 20, 2020 10:21 pm    Post subject: Reply with quote
had an etec on my old whaler. ran like a bat out of hell. Their a really fine tuned engine. They'll either run or they wont. They don't like running at low speed so if you do a bunch of trolling this isn't the one for you. The Seattle fire department hates theirs cause of how much slow putting they do... lots of issues.
Conrad Metzenberg
07' Tomcat 255 "Kanaloa"
87' Boston Whaler Guardian 17 (BlackFlag, 03-14)
davidjm
C-Dory Model: 19 Angler
Vessel Name: E-Z Rider
PostPosted: Tue Jan 21, 2020 1:35 am    Post subject: Reply with quote
I have a C Dory 19 with an E-tec 90 0n it, and a Macgregor with a Suzuki 70 4 cylinder, same block as the 90.
The Suzuki is much quieter than the E-tec, but weighs a lot more than the E -tec. If the motor your looking at is one of the ones that has the corrosion problems, then that's a deal breaker for sure.
My 2006 E-Tec has about 700 hours on it and I have spent about $5000 on maintance and repairs over the last 12 years. Boating can be expensive. I like the E-tec because it is about 50 lbs. lighter than the Suzuki and lighter is much better on the CD 19. I have my motor set to the 100 to 1 oil setting for synthetic oil, and about one half of my hours are at trolling speed, it doesn't smoke, but I change my plugs about every 75 hours. The end of the plugs burndown and when the gap gets to big the engine will start to run a
bit ruff.
I love my CD 19 Angler and use it all the time for fishing, crabbing, and shrimping in the San Juan islands, but why are you wanting to buy a fishing boat to do recreational cruising. I know some people do use the 19's and 16,s for cruising, but a CD 22 cruiser would probably work twice as well for cruising as a CD 19 Angler.
curioustraveler
PostPosted: Tue Jan 21, 2020 9:50 am    Post subject: Reply with quote
David,
How's your luck been with the Suzuki?
You're correct...the 22 is a better boat for cruising. We have specific reasons we're looking for a 19 though.
Also, I'm sending you a PM.
Page generation time: 0.0617s (PHP: 55% - SQL: 45%) - SQL queries: 28 - GZIP disabled - Debug on
